Yeti Can I safely run mamba x with castle 1410 motor in my yeti? Sent from my SM-G930VL using Tapatalk |
Re: Yeti I had a 1410 3800 KV 5mm unsensored in mine, paired with a Monster x. And it was fine. I only changed motor cause it was unsensored. Should be fine with a Mamba x also. I could gear mine up to 64/19 on 3s with no issues. And my Little Monster weights approx 10 lbs. Gesendet von meinem Pixel 2 XL mit Tapatalk |
Re: Yeti Thanks brother a big help. I'm getting a lot of heat out of mine after just a minute or so Sent from my SM-G930VL using Tapatalk |
Re: Yeti If it's hot: 1) check running gear for binding bearings and overtight gear mesh. 2) if not binding get smaller pinion. |
Thanks. Running 2s 500mah 30 c. Getting hot fast. 19/64 opinion and spur. Gears all seem good in tranny Sent from my SM-G930VL using Tapatalk Debating on going with holmes puller pro or puller pro xl....thought? Sent from my SM-G930VL using Tapatalk Its clogging in reverse too Sent from my SM-G930VL using Tapatalk |
Re: Yeti Quote:
maybe find some bearings to oil, that's really the only thing that wears out in the motor, replace them and good as new. |
Re: Yeti Quote:
Nice options"thumbsup" i changed to the puller pro R 540-L :mrgreen: I forgot to mentioned i have the 2 speed option in mine 8) also i have installed the included cooling fan on my 1410. But booth are great motors for the yeti:twisted: and i would consider to change to 3s. i power mine with 5800mAh 65C 3S zippy compact lipo's. (if it's not a typo;-)500mAh is a little small) |
