Thread: SCX 10 2 going full reverse without stopping
Old 12-29-2018, 12:41 PM   #1
Default SCX 10 2 going full reverse without stopping
Hi y'all,
My SCX 10 2 RTR is stuck in reverse. I checked my controller trim settings, I checked the reciever, I can still turn so my controller is still bound. I unplugged the esc from the reciever and it still runs full speed in reverse. I also replaced the batteries in my tx.
I'm thinking it is the esc but some advice would be great. The esc is the AxialAE-5
Thanks in advance for the help.
Alan
RCChameleon is offline   Reply With Quote
Old 12-29-2018, 12:54 PM   #2
Default Re: SCX 10 2 going full reverse without stopping
By chance have you accidentally bumped the throttle reverse switch on the backside of the remote?
Alexander_0_1 is offline   Reply With Quote
Old 12-29-2018, 01:05 PM   #3
I just checked. It is in the correct position, i even cycled it a couple of times.
Sent from my SM-T380 using Tapatalk
Old 12-29-2018, 01:10 PM   #4
And it’s still operating in reverse? Even though you’ve tried reversing the switch, then seeing if the throttle is still backwards?
That is strange, I’d’ve thought that the switch would make it operate the in the other direction.
I have one of those ESCs but I never powered it up, or read any information about how they operate.
Old 12-29-2018, 02:44 PM   #5
I agree, I thought it would change direction. I'mpretty sure my esc is fried somehow. I've never heard of this happening, lol
Old 12-29-2018, 03:39 PM   #6
I think your ESC is fried. Spend $40 on a Hobbywing 1080, the best bang for your buck brushed esc.
Sent from my SM-G960W using Tapatalk
MasteroFlego is offline   Reply With Quote
Old 12-29-2018, 03:46 PM   #7
Seems if you unplugged the esc from the reciever and it still does it, it's an esc issue. Not sure what it is, but I do know the best solution to fix it, unplug it complelty, pull it from your rig, and install a hobby wing 1080(as previously stated).
Sent from my SAMSUNG-SM-G920A using Tapatalk
Steve g is offline   Reply With Quote
Old 12-30-2018, 01:15 AM   #8
Have you tried calibrating the esc? perhaps disconnect the motor when you do so you don't need to chase it.
Even if that fixes the problem and the esc is not fried, I would still throw it away and buy a hobbywing 1080.
Voodoobrew is offline   Reply With Quote
SCX 10 2 going full reverse without stopping - Similar Threads
Brand new scx10 goes full throttle in reverse and occasionally reverses on its milestone Electronics 4 10-02-2013 07:35 AM
truck steers when in reverse and full throttle problem bro_die Axial SCX-10 3 07-08-2011 04:20 PM
Should i get full speed reverse on LNC? MikeinFresno Team Losi Comp Crawler 9 02-28-2011 02:01 PM
Why doesnt my reverse work to its full potential jimi hendrix Electronics 6 08-12-2009 11:18 PM
