Thread: Tactic TTX300 3rd Channel Lights
Old 01-05-2019, 07:45 AM   #1
Default Tactic TTX300 3rd Channel Lights
I am trying to see if I can use the 3rd channel to turn led lights on and off.
Currently I have the axial simple Led controller, part #AX24257.
Would I need to upgrade to the NVS controller if I want to turn the lights on and off using the tactic 3rd channel?
exedotbat is offline   Reply With Quote
Old 01-05-2019, 07:50 AM   #2
Default Re: Tactic TTX300 3rd Channel Lights
You need something like this:
Remote Switch For LED Lighting
heyok is offline   Reply With Quote
Old 01-05-2019, 08:51 PM   #3
Thanks
Old 01-05-2019, 09:19 PM   #4
I used the mytrickrc dragon setup on that remote, the headlights had 3 levels of brightness. More expensive then the heyok stuff but it was waterproof and came with lights.
Voodoobrew is offline   Reply With Quote
Old 01-06-2019, 06:14 AM   #5
Hey, most of my stuff is waterproof
Also, I make this controller (two versions - receiver powered and external powered) that does three levels of dimming:
Remote Switch for LEDs with Dim function
Here I tell you how to make your own light strings for basically pennies:
How to wire LEDs
Old 01-06-2019, 11:21 AM   #6
How to wire LEDs
What about kree or similar high powered leads? 1 to 3 watts. I couldent figure out which needed heat sinks, that's why I went with mytrickrc
Old 01-06-2019, 11:42 AM   #7
There are engineering formulas to take the specs and figure out how many degrees C per watt the temp will go up, but who has time for that?
Run one and if it gets hot, reduce the current going to it with a larger resistor in series. Then you also have to be aware of how much heat is being dissipated by the resistor. Gets to be a pain.
Here is something that I found works pretty well - I used to run this on one of my rigs that had easy places to put four of the 3 watt Cree LEDs - I ended up putting all four in series and because I was running it from a 3S lipo, the voltage worked out right so that the LEDs were super bright, but still running below spec (they didn't melt anything).
As fun as it was having that much light, it wasn't really practical, so I ran it from one of my dimming light controllers so it could be lit up, but not painful to use when I happened to be driving towards myself.
Tactic TTX300 3rd Channel Lights - Similar Threads
Tactic tx300 3rd channel for a winch RedlineMike Electronics 6 04-07-2018 09:05 AM
Tactic Tr325 3rd channel set failsafe position? Major Clod Electronics 1 01-29-2018 02:08 PM
Ttx300 3rd channel issue nate3923 General Scale Talk 3 03-05-2016 11:14 PM
