02-24-2019, 01:44 PM | #1 |
Quarry Creeper Join Date: Aug 2018 Location: Toronto, Canada
| Mamba-x. How are you guys protecting it from water?
I know that the mamba-x is waterproof, but I'm having issues with water getting into the area where wires connect to the ESC. Now, I've put dialectic grease on the sensor cables ends where the motor is and where the sensor wire connects, but the issue is that anytime water gets near the wires connected directly to the esc, things go nuts. How do I prevent water from getting into those connections? To be clear, I'm not driving in water, but snow does get into the chassis and water comes from that snow. |
02-24-2019, 03:13 PM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
| Re: Mamba-x. How are you guys protecting it from water?
Iv driven mine through pretty deep streams and also wash off any debris in the bath with a shower after and never had any problems although my friend got stuck in a really deep muddy puddle upside down for about 10 mins and it started flashing red and not working after , he took it home washed in the bath with a shower then dried the esc completely and cleaned it thoroughly by taking of the casing and using alcohol on the connections and it was fine after that , I have found water in the sensor wire before which might be your issue possibly,... you dry the terminals off on the male side and still have water stuck in the female side still ! Sent from my iPhone using Tapatalk |
02-24-2019, 03:18 PM | #3 |
This is happening with two Mamba-x ESC's and it's annoying. Water pools in the part where those wires are, so I'm not sure how to keep that area dry while out on the trails. After having to lug my TRX-4 for a half hour walk of shame, I felt it necessary to ask for help.
02-24-2019, 03:23 PM | #4 |
Smear silicon around the wires to prevent the build-up of snow perhaps Sent from my iPhone using Tapatalk |
02-24-2019, 03:27 PM | #5 |
| Re: Mamba-x. How are you guys protecting it from water? Already done that. The problem is specifically in the area where the wires connect to the ESC (not only the sensor wire, but the AUX and power switch wires. |
02-24-2019, 03:33 PM | #6 |
Try asking Robert from Castle creations he’s a good chap and I’m sure he’d be happy to give you some sound advice Sent from my iPhone using Tapatalk |
02-24-2019, 05:37 PM | #7 |
RCC Addict Join Date: May 2015 Location: Price Twp.
What issues? I'm willing to bet it is the on off plug giving you issues when wet. |
02-24-2019, 05:45 PM | #8 | |
| Re: Mamba-x. How are you guys protecting it from water? Quote:
Today, I ran 3 packs through my truck on a nearly 3 hour hike. Suddenly, the truck acted like it was losing power, so I tried a new battery and it was pretty much not moving right. I ended up carrying it back to the csr6, but once I took the ESC wires off and dried the water that was there, it worked fine. I had an issue with the power switch not working because of water getting into my other truck, but that was just the power switch stuck on the on position - the truck still ran fine. This time, the truck was DOA once water got to those wires. | |
02-24-2019, 06:10 PM | #9 |
Sill question but maybe mount it on its side....
02-24-2019, 06:21 PM | #10 |
| Re: Mamba-x. How are you guys protecting it from water? |
02-24-2019, 06:22 PM | #11 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
The on/off switch that Castle uses on the Mamba X is awful. Bypass it or replace it.
02-24-2019, 06:23 PM | #12 |
| Re: Mamba-x. How are you guys protecting it from water? I actually do like on/off switches on my truck, but let's say I snip it off and join the wires... What happens when the actual pins come in contact with water? Won't I just have similar issues, since the water isn't getting into the switch itself, but the pins on the esc.
02-24-2019, 06:31 PM | #13 |
I wonder if it might be worth putting some corrosion-x on the pins to keep water off and away : http://www.corrosionx.com/electronics.html They seem to suggest it will work and not interrupt the connection. |
02-24-2019, 06:44 PM | #14 | |
I like switches too. I replaced the one on my Bomber's Mamba X with a switch from a Hobbyking ESC. When the one in my Yeti goes, I think Ill put a toggle switch right in the center of the interior to simulate a shifter. | |
02-24-2019, 10:19 PM | #15 |
Quarry Creeper Join Date: Apr 2018 Location: US
Have you tried putting dielectric grease on the harness connector at the ESC? Should work I'd think. Sent from my Pixel 2 using Tapatalk |
02-24-2019, 10:23 PM | #16 | |
That's why I'm wondering if corrosion-x might be an option, since it shouldn't interfere with the actual connectors. | |
02-24-2019, 10:40 PM | #17 | |
Sent from my Pixel 2 using Tapatalk | |
02-24-2019, 10:46 PM | #18 |
02-24-2019, 10:59 PM | #19 |
02-24-2019, 11:18 PM | #20 |
Mamba-x. How are you guys protecting it from water? - Similar Threads | ||||
water jet guys, or plasma tables | ultimate_monkey | Chit Chat | 8 | 05-31-2010 10:40 PM |
protecting paper plates from water? | pantablo | General Scale Talk | 15 | 01-31-2008 11:35 AM |
Water Proofing a Mamba 25? | Spucknit | Electronics | 3 | 12-30-2007 11:20 AM |
Mamba maxx + water?? | EMUTT | Electronics | 9 | 04-08-2007 02:09 AM |
Water proof mamba | kingzero | Chit Chat | 11 | 09-01-2006 12:09 AM |
