03-02-2019, 03:14 PM | #21 |
| Re: Holmes hobbies revolver sound
It uses the same pwm as every other motor. It is possible to make an esc with a higher pwm bit it will also alter the performance. I dont remember what will change exactly but I think higher pwm makes a car less Punchy, increased heat in the esc (or motor, I don't remember which) and maybe smoother control. I assume there would be a limit to this increase kinda like overclocking a pc.
03-02-2019, 03:18 PM | #22 |
I very briefly experimented with putting a small container around the revolver and quickly gave up, It did very little but to create an echo chamber. I also worried about it trapping debris that the motor might ingest. It might be possible though, I put minimum effort into testing it. I was a bit exited that this item could have a cool name too, Revolver Silencer or something. Last edited by HumboldtEF; 03-02-2019 at 03:21 PM. |
03-02-2019, 03:32 PM | #23 | |
Rock Crawler Join Date: Jan 2019 Location: Calgary
| Re: Holmes hobbies revolver sound Quote:
03-02-2019, 03:35 PM | #24 |
You can get a similar result by gearing down and increasing motor speed with any other motor. From what I have seen the 1800kv revolver on 3s and 50:1 isn't any better then my 100:1 scx10 on a 2700kv puller pro running 4s. They have about 22,000rpm at the motor where I have about 45,000rpm. But both vehicles have the same top speed and mine seems to do better on the low end with a lower initial start speed. .
03-02-2019, 03:35 PM | #25 |
Rock Stacker Join Date: Mar 2019 Location: Canada
So I just did a quick test on the only similar motor I have. It's meant for an underwater thruster though so has a squeak from it's bushings but this is a 24khz pwm rate. There is still a harmonic from changeing steps but that can be made quite soft. There is no whine from pwm (Just the horrible squeak of the un-lubed bushing). https://youtu.be/2ENcO_Zp9ow |
03-02-2019, 04:01 PM | #26 |
I purchased a 1800KV outrunner knowing they were noisy. Turns out the noise was worse than I thought it would be. I used it only a short time in my #1 TRX4 and just could not stand the sound. Over the winter, I moved it to my Spartan so that at least I can't hear it out on the water.
03-02-2019, 04:17 PM | #27 | |
[IMG][/IMG] Last edited by durok; 03-02-2019 at 06:06 PM. | |
Holmes hobbies revolver sound - Similar Threads | ||||
Holmes Hobbies RevolveR 2 Givaway! | JohnRobHolmes | Electronics | 99 | 12-25-2006 11:09 PM |
