09-22-2020, 07:52 PM | #81 | |
| Re: Open source ESC and firmware Quote:
10-06-2020, 01:31 AM | #82 |
Ok so I have 2 Tutorials to share on this. I made one specifically for the Airbot Wraith32 35A v1 ESC and the other was translated from Chinese and might work on other esc's but I think its more for quadcopters. I believe my tutorial is pretty straight forward, and everything you need to know is there, with out having to guess at all. Please let us know how it goes or if I need to add more information. Or if you encountered problems. Airbot Wraith32 35A v1 ESC Not My Tutorial |
10-06-2020, 12:43 PM | #83 | |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
10-09-2020, 03:55 PM | #84 |
I don't know, i tested it on my phone with a different email and it opened, but i also have the link email on the phone too. Its not a large file. __________________________ Handy gearing spreadsheet |
10-16-2020, 01:28 AM | #85 | |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
10-18-2020, 04:05 AM | #86 |
| Re: Open source ESC and firmware Currently I know it can be setup in an airbot wraith32 35A esc, they cost about $15, and you need a St-link programmer, which is about $6 to erase and do the initial programming. After that you can get the code and modify it from https://github.com/AlkaMotors/AM32-M...r-ESC-firmware but there is no tutorial for that. AlkaM is tweaking things here and there. I have posted some videos of it on my youtube as well https://www.youtube.com/channel/UCq9...sj1N_UQ/videos There is a configurator, to do some tweaks kinda like castle link software, but for the most part its not for programming crawlers instead its for quads. |
10-18-2020, 01:42 PM | #87 |
Newbie Join Date: Jan 2017 Location: Bellingham
SO - My query is, could I piggyback a trinket or similar micro/nano arduino onto the fpv single esc for additional functionality and maybe easier programming/tweaking? They have bluetooth variants so tweaking through an app could become a possibility down the road. On a simpler level Im thinking about things like aux channel drag brake % tweaking or even throttle responsive led lighting. Im just dipping my toes in here so apologies for relatively naive wonderings. I grew up dicking around with rc and programming and am recently recovering from a serious fpv quad addiction. So I have a little bit of a basis to go off of for all this, but am still wading into unknown waters. Im absolutely stoked to see this kind of development happening. Ive been dreaming of an opentx style sbus radio and esc/driveunit offering for surface rc ever since I started getting in to fpv quads. Also something not so stupidly overpriced. |
10-19-2020, 01:21 AM | #88 |
| Re: Open source ESC and firmware Thanks , man!...I went through all your links and , honestly, too much tinkering for me I hope someone (HH,Castle, etc.) comes out with a plug and play solution in the future .
10-22-2020, 11:09 PM | #89 | |
As far as an arduino, that i would also conect directly to the reciever. Unles you want to use the telemetry from the esc. __________________________ Handy gearing spreadsheet Last edited by Voodoobrew; 10-22-2020 at 11:13 PM. | |
10-23-2020, 10:31 PM | #90 |
Well aware this is only an ESC. I just designated "FPV single ESC" to be specific that I was talking about a setup that used this specific kind of esc. Im interested in the idea of being able to adjust things like drag brake % on the fly through a third channel on the radio. The Castle esc's have this functionality and it would be nice to be able to adjust the drag brake when taking a truck on a longer trail walk/run. Adding a Trinket could also provide an LED uart rx for addressable LEDs around the truck. If this was available you could turn lights on/off through a fourth channel, and you could have the brake lights respond to throttle position. I just got 2 wraith32 esc's and an st link so ill start digging my toes in once I get a sec. Last edited by gvngoheavy; 10-23-2020 at 10:46 PM. Reason: added details |
10-31-2020, 02:07 PM | #91 |
something is happening !! https://www.youtube.com/watch?v=2p2pVkzBhmg |
12-03-2020, 08:44 PM | #92 |
Its going still, just a tough project on many levels. I'm working hardware for our needs, alka is still massaging software, and I've got Jonathan going on a programming interface. So far its looking good. I managed to develop a few motors with better tuned bemf that works better with the sensorless wave table. Luckily just had a ton of protos laying around to choose from, I like to make a range of magnet shapes for testing. |
12-11-2020, 01:53 PM | #93 |
Ok so I have some new firmware for the Wraith32 35a if any one is interested or has made one of there own already. It loads the same as before, I have it listed as ver3.0 and it gets rid of the heat issues from the previous version. You can download the firmware and the instructions from https://drive.google.com/drive/folde...cL?usp=sharing |
03-04-2021, 06:41 PM | #94 |
Quarry Creeper Join Date: Mar 2019 Location: Low CG
This is amazing! Well done guys and thanks for sharing. I've got two Wraith's and a ST-Link on order and will give it a try.
03-25-2021, 08:41 AM | #95 |
Newbie Join Date: Jun 2019 Location: Chesaning
Can this firmware be loaded from bl heli 32 suite configurator with a flight controller pass through?
03-29-2021, 02:01 PM | #96 | |
Then you can never use blheli or their configuration tool on it again. But after that you use a similar tool and program it via the servo wire like blheli. | |
03-29-2021, 02:03 PM | #97 |
It probably would be possible if blheli allowed you to flash 3rd party firmware, but they don't, nobody really does, because that makes it super easy to damage hardware.
04-19-2021, 01:29 PM | #98 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
This is an awesome project! I personally LOVE the sound of my revolver. I just want a 4s ESC... will this firmware work on any BLHELI32 esc? Lou |
04-20-2021, 02:23 AM | #99 |
| Re: Open source ESC and firmware |
04-20-2021, 05:47 AM | #100 |
I don't have one in mind but I know there are loads of drone ESC's that should fit the bill... Lou |
Open source ESC and firmware - Similar Threads | ||||
OEM Castle Esc reflash firmware | Di_Spencer | Electronics | 9 | 12-06-2016 11:36 PM |
Open source chassis | Savagethrash | Axial XR10 | 2 | 03-22-2015 06:12 AM |
TorqueMaster ESC 1.08 firmware released | JohnRobHolmes | Electronics | 13 | 03-04-2011 06:23 AM |
Xcelorin ESC firmware download | Del Monte | Team Losi Comp Crawler | 16 | 03-09-2010 12:07 PM |
Open source or free sw to replace Autocad | setecastronomy | Tools, and Procedures | 16 | 04-28-2009 06:24 AM |
