Thread: Identifying Hitec servo
Old 04-27-2019, 10:27 AM   #1
Default Identifying Hitec servo
My newest rig came with a hitec servo but the sticker is gone. I know on the side there is a date code, and inside the case is a case number, other then that I don't know what model it is. Any way to find out?
Sent from my SAMSUNG-SM-G920A using Tapatalk
Steve g is offline   Reply With Quote
Old 04-27-2019, 01:19 PM   #2
Default Re: Identifying Hitec servo
Some will ask for pics ,
pics would help out a lot in this situation.
Frank211 is offline   Reply With Quote
Old 04-27-2019, 01:28 PM   #3
color? spline count? Case material? What are the numbers that you did find?
TheLetterJ is offline   Reply With Quote
Old 04-27-2019, 01:47 PM   #4
It's aluminium black case with shiny lines, I believe 25t, all I can remeber now. (Do yourself a favor and don't get old) servo wires are twisted together.I can get pics and more info tomorrow when I'm there. Maybe tonight even.
Old 04-27-2019, 01:57 PM   #5
Maybe HS-7954SH which i have used for a while myself.
https://hitecrcd.com/products/servos...7954sh/product
Peaker is offline   Reply With Quote
Old 04-27-2019, 02:52 PM   #6
If OP is correct that his is 25 spline, it's not a 7954, 7950, 7955, ect.
HahnsB2 is offline   Reply With Quote
Old 04-27-2019, 03:48 PM   #7
Never trust the op...
So it's a 24t. Titanium gears. It's a 5998tg. Not to impressive specs, but it's not to bad
Old 04-27-2019, 06:16 PM   #8
Just wanted to add, on the inside of the front of the case it said HSC5998. The reason I didn't Google that number is because I read another thread of someone who had the same question, and he said those numbers identifies the case only, not the servo. Apparently he was wrong. So in case anyone in the future reads this, the model number is written on the inside of the case. It didn't say tg, for titanium gears, but a quick magnet test will let you know if it's titanium (not magnetic) or metal (magnetic).
Identifying Hitec servo - Similar Threads
Help identifying Hitec servo Chainsaw10 Electronics 6 05-25-2015 07:09 PM
Need Help Identifying a Servo STJ7780 Electronics 3 01-20-2011 06:29 AM
need help identifying these trusses/servo mounts. BigSki Tamiya TLT Crawlers 18 01-29-2009 07:47 PM
