04-27-2019, 06:04 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
| Portable/travel charging setup
I'm thinking about running 4 gauge cable, from my vehicle battery, to the cargo area to connect my 800W inverter, for battery charging, or other electrical accessories. Got me wondering what other unique, or efficient charging setups were out there for travelling, or going to events. Sent from my SM-J727V using Tapatalk |
04-27-2019, 06:18 PM | #2 |
Rock Crawler Join Date: Dec 2009 Location: Suffolk
| Re: Portable/travel charging setup
My 4runner has a 400W 115V outlet in the cargo area from the factory, so I just use my Hitec X4AC plus plugged into that. It works great just need to idle the 4runner while I charge.
04-28-2019, 05:46 AM | #3 |
Newbie Join Date: Mar 2019 Location: Kamiah
My dodge has the 110 plug on the dash. But I could see where having a charging port somewhere in the bed would be nice.
04-28-2019, 12:58 PM | #4 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
I use a cheap plug in inverter along with my ac charger. It's easy to size. All my batteries are 3S 2200mah and I only charge at 1C. (12.6*2.2)*1.20 = 33.26 A 35 watt inverter would suffice, I got an 85w for 10 bucks on sale, works great. Could do 2C with it if I had too with no issues. |
04-28-2019, 01:44 PM | #5 |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
My ProTek RC charger runs off of AC or 12V DC, so no need to convert DC to AC back to DC. I like it, since I can connect directly to my vehicle battery or travel trailer battery. No need to worry about blowing any fuses. My truck has an AC plug in the cab, but it is only rated for 1.25A. Sent from my iPhone using Tapatalk |
04-28-2019, 08:51 PM | #6 |
i have a couple of cheap imax chargers one has 110 and 12v input the other only has 12v input and uses a 110 to 12v converter plug to get 12v
04-29-2019, 07:48 AM | #7 | |
| Re: Portable/travel charging setup Quote:
Should easily be enough to charge a 3s battery at upto 10a. | |
04-29-2019, 02:06 PM | #8 | |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
That's exactly what I was planning to do with my Forester, I would prefer charging in the cargo area where I am wrenching or have my staging table setup this way I don't need to keep the hood open. I would suggest a fuse of course. I will most likely put the system on a relay and switch and fuse block so I can expand later | |
Portable/travel charging setup - Similar Threads | ||||
Your Charging setup/station ? | ScaledforFun | Electronics | 8 | 07-23-2013 01:34 PM |
cc01 with droop setup=lots of rear travel | nosyajg | Tamiya XC/CC01 | 8 | 04-17-2011 02:46 AM |
Sprung suspention question: Does your shock/spring setup have any down travel? | BigB_117 | General Crawlers | 7 | 10-28-2009 12:04 PM |
VF DIG setup & digital travel numbers :) | Mule | Axial AX-10 Scorpion | 11 | 06-06-2008 10:22 AM |
Portable field charging? | DeaDShorT | Electronics | 20 | 02-20-2007 07:29 AM |
