Thread: Hobbywing Axe + External BEC wiring.
Old 04-27-2019, 11:03 PM   #1
Default Hobbywing Axe + External BEC wiring.
I have a hobbywing AXE on my crawler. I’d like to add a Castle 2.0 BEC. I was looking at using the Holmes Rx bypass harness but ran into a dumb question. The Castle BEC has two outputs to the receiver. Do I need to get two of the Holmes rx bypass harnesses? Or would it be better to not use the Holmes bypass and just remove the red wire feeding the receiver?
Tree_Mafia is offline   Reply With Quote
Old 04-27-2019, 11:26 PM   #2
Default Re: Hobbywing Axe + External BEC wiring.
The Holmes bypass is just for people who won't modify plugs themselves. Either for warranty reasons or not wanting to solder or just wanting to keep the origional plug unchanged for easier servo swapping later, but it's only a better choice if you can't solder well or don't want the hassle of figuring it out yourself imo.
Sent from my SM-N950U using Tapatalk
Voodoobrew is offline   Reply With Quote
Old 04-28-2019, 05:32 AM   #3
Plug and play.
The 2.0 bec has two 10a outlets , you only use one with one servo . The rx bypass eliminates cutting, pulling or soldering, leaving the esc stock
Hang up and Drive
mikemcE is offline   Reply With Quote
Hobbywing Axe + External BEC wiring. - Similar Threads
Hobbywing Xerun AXE Jboucher Electronics 565 06-27-2023 05:45 AM
RC4WD Gelande Defender / Hobbywing Xerun Axe TerryTurnip 1.9 Scale Rigs 2 04-04-2019 04:07 AM
PRICE DROP Hobbywing AXE Lineup! RPP Hobby RPP Hobby 0 12-13-2018 12:37 PM
NEW Hobbywing North America XeRun AXE 2300kv Combo In Stock! RPP Hobby RPP Hobby 0 06-29-2018 11:51 AM
Open for Pre-Order! NEW Hobbywing XeRun AXE Combos! RPP Hobby RPP Hobby 0 05-31-2018 12:36 PM
