Thread: Gearing
Old 05-09-2019, 04:00 PM   #1
Default Gearing
I have a crawler with 55t motors. I swapped them for 27 t motors. How many teeth do I have to take off the pinion to make the 27 t preform the same as the 55 t?
Iceman29488 is offline   Reply With Quote
Old 05-09-2019, 05:40 PM   #2
Default Re: Gearing
My guess would be... cut it by half.
Even if you get the same wheel speed, the 27t should give a nice bump in power/peak wattage, and a lot smoother startup (when geared for the same top speed.)
TheLetterJ is offline   Reply With Quote
Old 05-09-2019, 07:29 PM   #3
Default Re: Gearing
Holmes lists their 27t torquemaster 540 as equivalent to 2200kv. Their 55t torquemaster 540 they list as equivalent to 1000kv. Hope that helps.
Smokin' Joe is offline   Reply With Quote
Old 05-09-2019, 08:15 PM   #4
Default Re: Gearing
Thanks, think I got it
Old 05-09-2019, 10:12 PM   #5
Default Re: Gearing
If you want it to perform the same you should get another 55T motor. Even if you cut the gearing in half you will be stuck with more torque and power...
Voodoobrew is offline   Reply With Quote
Gearing - Similar Threads
High Turn Motor & Long Gearing vs Low Turn Motor & Short Gearing. Hardcoretam Electronics 11 03-15-2017 11:23 PM
Gearing help OTHGbronco82 General Crawlers 0 08-05-2014 07:48 PM
1.9 wk gearing? bigblazerboy General Crawlers 2 02-18-2008 05:31 PM
1.9 gearing? bigblazerboy HPI Wheely King 2 02-17-2008 12:47 PM
