05-11-2019, 09:01 PM | #21 | |
| Re: Piece of connector strip to connect ESC and motor? Quote:
I've got it!!! Lets all go back to using Tamiya (molex) plugs!!! Those were great, why did we ever stop using those, its not like they melted or anything...? | |
05-13-2019, 09:52 AM | #22 | |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
I'm curious about those because it's clearly a low melting point solder, but I'm not sure how well it would hold up in an R/C application. It's possible the solder would melt from the current going through it but the shrink might hold the wires together and keep the connection through the liquid solder. For a crawler it would probably be fine and never melt, but anything else I would be concerned. We've had proper solder joints come unsoldered just from the current. | |
05-13-2019, 10:27 AM | #23 | ||
05-13-2019, 12:13 PM | #24 |
A crimped connection with conductive grease would be the best connection overall, the mechanical pressure between conductors is fantastic for conductivity and the grease keeps it from corroding. Soldering is good enough for most RC needs though, and is more convenient for the home hobbyist.
05-13-2019, 04:02 PM | #25 |
Don't need grease if you use the heat shrink sleeve crimp connectors. Just crimp and heat, the connection is permanent and sealed. These are the only type of crimp butt connectors and terminal ends that I use any more. https://www.mcmaster.com/butt-connectors This is sad, good God man buy a $20 soldering iron and learn a new skill! It's so easy even a cave man could do it. Last edited by Inspector86; 05-13-2019 at 04:33 PM. |
05-13-2019, 07:31 PM | #26 |
I've seen corrosion get places it shouldn't and ruin wires. I never ever crimp without a nice coat of grease. even dielectric is better than none.
Piece of connector strip to connect ESC and motor? - Similar Threads | ||||
What's the ideal connector for ESC/battery/motor ? | skyjockey | Newbie General | 44 | 10-17-2019 10:52 AM |
did I get the wrong connector? ESC to motor | IPT | Electronics | 5 | 05-20-2014 06:42 AM |
how do i connect the ESC, BEC & battery?? | SwampDawg | Newbie General | 10 | 10-08-2010 12:37 PM |
What type motor connector comes on Sidewinder esc? | neuro242 | Electronics | 8 | 09-04-2009 07:22 PM |
