05-18-2019, 10:30 AM | #1 |
Newbie Join Date: Dec 2018 Location: Den Hoorn
| Servo winch on Spektrum DX5c
Hi all, I would like to control a servo winch with my spektrum dx5c and 6000 receiver. How have you set this up? Using aux channels 1,2,3 for diffs and gear. Aux4? Verzonden vanaf mijn iPhone met Tapatalk |
05-18-2019, 10:45 AM | #2 |
Rock Stacker Join Date: Oct 2016 Location: NYC
| Re: Servo winch on Spektrum DX5c
I've been having issues using my DX5C with a winch. My fourth channel automatically sets to either in or out once I plug in my battery then functions as normal when the reciever is turned on. Even if it's just for half a second, it will still spool. I've tried setting the failsafe to a neutral position and it does nothing. Tried switching to my 3rd channel and it works perfectly fine. I think there might be something up with my transmitter. My setting for 1-3 is steering, throttle, and dig. Sent from my iPhone using Tapatalk |
05-18-2019, 11:14 AM | #3 |
My issue is that I can’t assign aux4. Have the 6000 receiver. Or am I using up all 5 channels allready? Verzonden vanaf mijn iPhone met Tapatalk |
05-18-2019, 11:15 AM | #4 |
I don't have an avc reciever so maybe you have to disable that first? Sent from my iPhone using Tapatalk |
05-18-2019, 11:18 AM | #5 |
I did that indeed, that cleared up channels 2,3 Verzonden vanaf mijn iPhone met Tapatalk |
05-18-2019, 11:20 AM | #6 |
What else do you have connected? Sent from my iPhone using Tapatalk |
05-18-2019, 11:21 AM | #7 |
2 Diffs and gearbox shift servo Verzonden vanaf mijn iPhone met Tapatalk |
05-18-2019, 11:23 AM | #8 |
Have you tried setting it up on 5? Maybe try moving one of the diffs to 4 and the winch to one channel that you know works? What exactly is happening when you try to set it up? Sent from my iPhone using Tapatalk |
05-18-2019, 12:58 PM | #9 |
The winch works on aux2. I can’t assign aux4 to a switch Verzonden vanaf mijn iPhone met Tapatalk |
05-19-2019, 08:59 AM | #10 |
But conclusion is that I’m missing a channel. Will free up one by trying to yharness the diffs (with a servo signal reverse in that case). Verzonden vanaf mijn iPhone met Tapatalk |
05-19-2019, 11:18 AM | #11 | |
Quarry Creeper Join Date: Apr 2018 Location: US
| Re: Servo winch on Spektrum DX5c Quote:
Sent from my Pixel 2 using Tapatalk | |
05-19-2019, 05:41 PM | #12 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
You could also try leaving the rear locked 24/7, that'll free up a channel and you'll hardly notice the difference on the trail.
05-20-2019, 12:15 PM | #13 |
Yup... Ch1: Steering Ch2: Throttle Ch3 (AUX1): Winch Ch4 (AUX2): Transmission Ch5 (AUX3): Differential locks Given that its a 5-channel radio, Ch6/Aux4, will not work. The RX is the same one used in the DX6R, and it will work with that radio. To get the differential locks to work on one channel you need a Traxxas T-Lock module. When assigning switches, go to your trim settings and see what switches the steering and throttle trims are already assigned to, and resign them if you want to use the switches they are on. |
05-20-2019, 12:17 PM | #14 |
The problem I was having is that the 4th channel on mine was not setting a proper failsafe. So it would just wind my winch non stop. No matter what I tried that 4th channel was acting up. Switch my dig to that channel and it did the same thing with the servo. Sent from my iPhone using Tapatalk |
05-20-2019, 12:20 PM | #15 | |
05-20-2019, 12:22 PM | #16 | |
I'm confused by this because once my transmitter is on the winch functions as normal. If I ugh my battery in, the winch automatically starts spooling. Once it connected to the transmitter it stops and works normally Sent from my iPhone using Tapatalk | |
05-20-2019, 12:26 PM | #17 | |
05-20-2019, 12:30 PM | #18 | |
Transmitter on first, then turn on the RC. Turn off the RC, then turn off the transmitter. | |
05-20-2019, 12:30 PM | #19 | |
I only have 3 things connected. My setup is: Steering ch1 Throttle ch2 Dig ch3 DX5C with 4ch sr415. So that last channel isn't usable? What's the point in a 4th channel if it can't be used? Sent from my iPhone using Tapatalk | |
05-20-2019, 12:31 PM | #20 | |
I know this, but even just that 1 -2 seconds before it binds with the transmitter it's spooling my winch that's already wound tight. Sent from my iPhone using Tapatalk | |
Servo winch on Spektrum DX5c - Similar Threads | ||||
Spektrum dx5c | wcdfmt510 | Electronics | 11 | 08-22-2021 10:39 PM |
Radio upgrade - Spektrum dx5c | Drenon88 | Redcat Crawlers | 0 | 03-19-2019 08:53 AM |
Spektrum DX5C MoA | Voodoobrew | Electronics | 6 | 08-11-2018 01:23 PM |
Spektrum DX4C vs DX5C | Taurus84 | Electronics | 8 | 05-10-2018 02:37 PM |
Spektrum dx5c | sherman918 | Electronics | 6 | 03-11-2018 08:37 PM |
