08-08-2019, 11:16 PM | #1 |
Quarry Creeper Join Date: Nov 2005 Location: LBC
| temporary 3 position switch to raise/lower tow boom?
I'm trying to figure this out and having trouble. I'd like to use 3 position switch on one of my channels (the momentary on-off-on type) to operate a servo powered tow boom. Basically I want to be able to bump the switch a little and raise/lower it as much or as little as I want. It also needs to hold it's position and not creep. Winches are somewhat similar in how you can reel them in and out, but I need it to stop at the end of the servo's original degree of travel. Does this make sense? Any idea how I can accomplish this? Last edited by shutupanddrive; 08-09-2019 at 11:40 AM. Reason: wrong terminology |
08-08-2019, 11:33 PM | #2 | |
| Re: temporary 3 position switch to raise/lower tow boom? Quote:
Sent from my SM-N950U using Tapatalk | |
08-09-2019, 09:38 AM | #3 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
You sould send Al @ HeyOK electronics a message, he almost certainly has a plug n' play solution for you. Or just use an esc (or winch controller), programmed to a channel withe a 3-pos momentary switch and set the end points to limit travel. |
08-09-2019, 12:26 PM | #4 |
What are you using on the truck to move the boom?
08-10-2019, 10:16 AM | #5 |
The radio is a modded CT6B, nothing too fancy. I might switch over to a th9x though because I need more channels. Maybe it's possible with that radio? For moving them boom, I'm just using a servo. I should reach out to Al it seems. Maybe he can help me wrap my head around this. I need things to work a very specific way and just can't figure it out on my own. I've done a lot of digging/reading here though and see that he has some amazing products and knowledge! Thank you all for your time and help! |
08-11-2019, 04:17 AM | #6 |
Just Set one of the buttons to adjust the servo trim and done. Sent from my SM-N950U using Tapatalk |
temporary 3 position switch to raise/lower tow boom? - Similar Threads | ||||
3 Position Switch for 4WS | FTRC | Electronics | 5 | 03-16-2019 08:42 AM |
anyone raise the lower links and cut the chassis | Jcplante | Redcat Crawlers | 8 | 08-26-2011 02:00 PM |
3 position switch help mx-sport | spgrading | Electronics | 0 | 12-19-2009 05:55 PM |
M8 3 position switch? | C_Money | Electronics | 3 | 05-19-2009 02:25 AM |
3 position switch on spektrums | Rumhead | Electronics | 27 | 01-31-2009 09:50 AM |
