10-18-2019, 01:36 PM | #1 |
Newbie Join Date: Oct 2019 Location: Cortlandt Manor
| Exceed RC 6x6 build
Hello I am building a 6x6 overkill truck but i need some help.What is the best transmitter for 3 Moa motors? Its 266.4v so far and 88.8v per motor. 1. tp power 4070 4d " 3 motors" 2. flier water-cooled 800a 22s esc 3. capo air ride v1 or v2 4. Copper foil 10mm" wrap around motor for cooling" PLEASE LEAVE SUGGESTIONS THANK YOU 5. wtf fans for motor " 3 fans per motor 6. mudslingers clod txt 1 7. Rc4wd demolishers beadlock wheel adapter revo/summit 8. 6x6 steering conversion 9. maxamps 12s 12000mah lipo " 2 per motor" 10. deans parallel connector Last edited by Ebuka Emelumadu; 10-26-2019 at 05:42 AM. |
10-19-2019, 10:35 AM | #2 |
| Re: Exceed RC 6x6 build
I would just use dual hw880 esc's. Or maybe a 1080 for the front esc. No need to overcomplicate things. Sent from my SM-N950U using Tapatalk |
10-19-2019, 10:55 AM | #3 |
| Re: Exceed RC 6x6 build The build is 16s with Tp power 4870 and 12s maxamps 12000mah + 3 4s maxamps lipos parallel connector motor there are 3 motors.
10-19-2019, 02:40 PM | #4 |
| Re: Exceed RC 6x6 build |
10-19-2019, 02:41 PM | #5 |
Many tx/rx's can do front and rear no problem. Sent from my SM-N950U using Tapatalk |
10-19-2019, 02:44 PM | #6 |
Honestly though I think you don't even need to vary the speeds of the motors unless you want dig. The motors automatically overdrive themselves when you climb stuff because there is more resistance on the back axle from the weight transfer. Sent from my SM-N950U using Tapatalk |
10-19-2019, 05:26 PM | #7 |
10-19-2019, 07:44 PM | #8 |
Yes that splits the voltage. You need to split it between the reciever and the esc. Front esc uses AL 3 wires to throttle ch. Rear 2 esc's get the red wires cut and y into the reciever. Cut the red wire on this y harness and maybe you don't void any warranty Last edited by Voodoobrew; 10-19-2019 at 07:46 PM. |
10-19-2019, 08:53 PM | #9 |
| Re: Exceed RC 6x6 build Thx
10-20-2019, 07:32 AM | #10 |
How do you increase the amp draw on a brushless motor?
10-24-2019, 08:18 PM | #11 |
10-26-2019, 05:38 AM | #12 |
10-26-2019, 08:14 AM | #13 |
i must be missing something here exceed moa 88v per motor 3 water cooled esc 3 giant brushless motors air ride big sticky tires and rims the parts listed cost more than my first house for a rig that wont even make it out the door is this some kind of trolling or something the exceed axles wont hold up on 2s with a 45t motor let alone a 4070 anything on any voltage the motor listed is only rated for 22 volts looks like a awsome motor but i dought it would even fit on the axles 12s 12000mah batterys are gona be huge and heavy i dought the axles can carry the weight let alone finding a place to put them |
10-26-2019, 08:19 AM | #14 | |
ill fix it for ya Quote:
that looks more like a exceed build | |
10-27-2019, 08:59 AM | #15 | |
| Re: Exceed RC 6x6 build Quote:
Exceed RC 6x6 build - Similar Threads | ||||
Another SUX 10 based 6x6 Traptor build, named Texas Pete. And it's not 6x6 yet, I ran | tcanin00 | Multi Axle Rigs | 11 | 05-26-2019 04:49 PM |
Give me real reviews, from real owners, exceed mad torque 6x6 | Misfit650 | Multi Axle Rigs | 10 | 12-29-2015 11:47 PM |
Exceed Maxtstone 10 Build | Maxstonescaler | General Crawlers | 10 | 05-01-2014 04:49 AM |
hey look Exceed rc's are going 6x6 | kgb424 | Multi Axle Rigs | 8 | 01-28-2014 06:08 AM |
Exceed 6x6 | Dirt Chucker | Traxxas Crawlers | 8 | 01-21-2014 08:33 AM |
