11-23-2019, 11:40 AM | #1 |
Rock Stacker Join Date: Apr 2019 Location: Koprivnica
| Servo servicing
So, I have killed multiple servoes up until now, but a few of them have burnt electronics, busted gears, or loose pinion (didn't know that could happen, but it did today). I was thinking of switching faulty parts of different servos to make a franken-servo. So far, no success. Whatever I do.. the servo works weird. Mostly not working. The strangest thing happened today.. So I got a free spinning pinion on my servo motor. It's just turning the axle, not moving the gears. I took a very similar servo, with the same size motor, and just soldered the good motor in place of the free spinning one. It was a 5 minute job.. but it doesn't work. When I put the servo together and plug it in... my winch starts spinning, and the steering doesn't work. Like the servo mixes up the channels. Have no clue why...Do you have any ideas why those swaps don't work??
11-23-2019, 05:32 PM | #2 |
| Re: Servo servicing
End Points, End Points, End Points!!! If not set properly, all of the above can and will happen. Hang up and Drive |
11-24-2019, 04:23 PM | #3 | |
| Re: Servo servicing Quote:
Yes, end-point adjustment is critical in order to keep your servos alive! If your transmitter doesn't include them, maybe one of these will help you: https://www.freewebstore.org/heyok-p..._18344974.aspx You can also read a little about them here: End point adjuster for two position channel | |
Servo servicing - Similar Threads | ||||
***Crawler Innovations Engraved Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 106 | 10-20-2013 02:16 AM |
Which oils/greases for servicing? | josef86 | Axial SCX-10 | 3 | 05-11-2013 06:11 PM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 228 | 07-12-2011 01:17 PM |
Crawler Innovations Servo Guard - Servo Clamp - Servo Mount GIVEAWAY!!! | Nova's Ark | General Crawlers | 219 | 10-18-2010 12:43 PM |
Dremel servicing | ecoli | Tools, and Procedures | 2 | 08-16-2009 02:02 PM |
