11-23-2019, 05:41 PM | #1 |
Quarry Creeper Join Date: Jul 2015 Location: Menifee
| Hw1080 with hh crawlmaster sport 550 12t on 3s?
Reading the specs on the 1080 >16t motor on 3s Has anyone been running crawlmaster sport 550 12t 1700kv on 3s? |
11-23-2019, 05:59 PM | #2 |
| Re: Hw1080 with hh crawlmaster sport 550 12t on 3s?
Yes, I bought a 12t 550 crawlmaster sport for my neighbor and he's been running it on a wp1080 and 3s exclusively. No issues at all, smoothest cheap motor I've run. I believe all the turn limits on esc's are generally assuming it's a 3 slot anyway.
11-23-2019, 06:12 PM | #3 |
RCC Addict Join Date: Jun 2017 Location: Canada
Yeah turn limits are for 3-slot motors You can run the 5-slot on it as well I think it's about X2 for the turn numbers of a 5-slot to a 3-slot ratio? Sent from my Pixel 2 XL using Tapatalk |
11-23-2019, 06:27 PM | #4 |
Thanks I figured it would be ok not unhappy with 2s. Just thought I would throw in a 3s to see how the slow speed crawling is
11-23-2019, 08:06 PM | #5 |
I run the 550 10t cm on 3s, no problem, just watch the gearing. Sent from my SM-N950U using Tapatalk |
11-24-2019, 09:21 AM | #6 |
Rock Stacker Join Date: May 2019 Location: Upstate, NY
[QUOTE=Voodoobrew;5979060]I run the 550 10t cm on 3s, no problem, just watch the gearing. Can you further explain "just watch the gearing"? Is that meant in regard to heat? I'm a noob building a TRX4 Sport using a CM 15t on 3S w/ 9/45 gearing. Looking for really good low speed control over speed on trail runs. |
11-25-2019, 01:40 AM | #7 |
Yes, if the pinion is to big it can over heat. If the motor gets too hot to touch for more then 3 seconds get a smaller pinion. Well too hot to touch for more then 3 seconds is hotter then recommended but probably won't cause damage right away Sent from my SM-N950U using Tapatalk |
11-25-2019, 01:42 AM | #8 |
Well if you have a 9t pinion you probably won't have heat issues on a trx-# Sent from my SM-N950U using Tapatalk |
11-25-2019, 01:21 PM | #9 |
Thanks - another learning experience!
Hw1080 with hh crawlmaster sport 550 12t on 3s? - Similar Threads | ||||
New Crawlmaster Sport 540 and 550 motors! | JohnRobHolmes | Electronics | 53 | 01-16-2020 04:21 PM |
New Crawlmaster Sport 540 and 550 motors! | JohnRobHolmes | New Products and Great Deals | 0 | 09-20-2019 05:52 AM |
Traxxas 550 12t | 2FAT | Electronics | 17 | 08-09-2019 08:03 PM |
rooster crawler and a 12t 550 | Erik R | Electronics | 5 | 09-04-2010 07:32 PM |
xl5 and titan 12t 550 | ct03si | Electronics | 5 | 06-13-2009 07:03 PM |
