11-30-2019, 07:20 PM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: US
| Reverse servo polarity?
Hey all Trying to wire up a trx6 to my 4 channel futaba setup. I need to merge the front and rear diff servos into 1 channel. I know I’ll lose the ability to operate them separately for now but I’m ok with it for the time being. If they work the same (both lock/unlock) then I am good. If not I’ll need to reverse one. Can I swap the positive and negative wires in the plug? That’s how you reverse a motor usually but idk if there is circuitry inside these micro servos that I’ll short if I do that... or if anyone knows a better way I’m all ears. TIA |
11-30-2019, 07:29 PM | #2 |
| Re: Reverse servo polarity?
You would reverse them in your radio, not the car. Sent from my SM-N950U using Tapatalk |
11-30-2019, 08:30 PM | #3 | |
| Re: Reverse servo polarity? Quote:
If there isn't a straight-forward means of doing it electronically, I can physically flip the servo around backwards. Though that will mean starting over with setting the linkage to move the cable in and out. I was hoping to avoid that. | |
11-30-2019, 08:36 PM | #4 | |
Sent from my SM-N950U using Tapatalk | |
11-30-2019, 09:05 PM | #5 |
| Re: Reverse servo polarity? Yeah I kinda figured. Thank you for your help! Guess it’s time time to get a 7px or a hacked fly sky. Any advice on where to find a fly sky?
12-01-2019, 04:16 AM | #6 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
Could buy a server signal reverser, they're $5 on Amazon
12-01-2019, 09:30 AM | #7 |
| Re: Reverse servo polarity? |
12-01-2019, 11:46 AM | #8 |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
12-01-2019, 06:26 PM | #9 | |
| Re: Reverse servo polarity? Quote: | |
12-02-2019, 03:28 PM | #10 | |
Reversing the two motor wires will get you halfway there. You also need to swap the two outside wires on the position sensor pot inside the servo. If you forget to do that, the servo will just try and go full power in one direction until something either snaps or burns out. | |
12-02-2019, 04:02 PM | #11 |
It works fine for me and countless others. It doesn't reverse the two wires, it reverses the signal itself, the servo won't see any difference whatsoever. Think of it like a pwm dip turning into a peak at the circuit on the signal wire, and in tune, a peak becoming a dip. It's not simply a harness that changes polarity of the DC input. It flips the signal sent from the receiver to the servo. Last edited by Xx Losungen xX; 12-02-2019 at 04:07 PM. |
12-02-2019, 04:06 PM | #12 | |
I wasn't saying the servo reverser circuit wouldn't work. I was saying that swapping the motor connection wires won't work unless you take an additional step. | |
12-02-2019, 04:11 PM | #13 | |
I was just clarifying that a servo reverser circuit will indeed work, as you seem to agree with in your latest reply. Life is good mate | |
12-02-2019, 04:14 PM | #14 | |
Sorry - it made sense in my head. My mistake. | |
12-02-2019, 04:17 PM | #15 | |
Was in the spirit of not dissuading the op or anyone else to come across this post from trying one out. | |
12-03-2019, 06:45 AM | #16 |
A Traxxas T-Loc is what you want for this application, it is specifically made to do what you are trying to do.
12-03-2019, 07:20 AM | #17 | |
A T-Loc will give you the ability to switch between: - Front Locked - Rear Locked - Both opened The OP would still need a servo reverser though. Adding the T- Loc on top of the servo signal reverser would give him the above features but I do believe it eliminates the ability to have both differentials locked at the same time (I could be wrong on that one). | |
12-03-2019, 08:06 AM | #18 | |
I smell what yer cookin. Sent from my SM-N950U using Tapatalk | |
12-09-2019, 06:50 PM | #19 |
Well this turned into quite an enlightening discussion. I love forums for this! Just to update, I got the reverser and it works wonderfully. It’s now either all locked or all unlocked by a Futaba 4PL. I didn’t try to cram all the mess and the Y connector I made in the Traxxas receiver box. I don’t think it’d fit.
12-10-2019, 04:50 AM | #20 |
You could take it a step further if your soldering skills are half decent. If your reverser is shrink-wrapped you could carefully cut that off and add a short pigtail to the input side, parallel with the existing pigtail. If you do that, you won't need the spaghetti mess of the Y harness. - Plug the original connector of the reverser into your receiver. - Plug one servo into the new pigtail you added to the input side of your reverser - Plug the other servo into the output side of your reverser Might all fit inside the box now. Electrically it'll all be the same as using the Y connector, just a little tidier. |
Reverse servo polarity? - Similar Threads | ||||
reverse polarity? | MacCrawl | Electronics | 5 | 05-06-2015 09:01 PM |
Hello accidentally did reverse polarity | jacobismynickname | Electronics | 6 | 03-25-2015 11:38 PM |
Can I reverse polarity on a Servo?? | savagefromthesprings | Electronics | 11 | 09-07-2009 10:40 AM |
REversing Servo Polarity ? ? ? | chivas72 | Newbie General | 10 | 02-27-2007 11:45 AM |
Reverse Polarity on Integy 55t | Trikster | Electronics | 2 | 08-03-2006 01:22 PM |
