12-10-2019, 11:41 AM | #1 |
Pebble Pounder Join Date: Mar 2019 Location: Ecuador
| Mamba X problems
I have a Mamba X and a HH puller pro stubby. (Brushless sensored)At first it was all right. Now with the sensor connected the motor overheats immediately when I reverse it just shakes, and after a few seconds of throttle it stops. If I disconnect the sensor it works both front and reverse throttle but what’s the point of having a sensored motor. I used the castle link and it is configured to *smart sense Don’t know what else can I do. Please help! |
12-10-2019, 11:46 AM | #2 |
Pebble Pounder Join Date: Jan 2018 Location: Northeast Iowa
| Re: Mamba X problems
sounds more like a motor issue to me bud i dont know. maybe get @JohnRobHolmes in here to help? Sent from my SM-G965U using Tapatalk |
12-10-2019, 11:51 AM | #3 |
| Re: Mamba X problems |
12-10-2019, 12:11 PM | #4 |
Bad sensor cable?
12-10-2019, 12:12 PM | #5 |
12-10-2019, 12:13 PM | #6 |
do you have warranty under castle send it in Sent from my SM-G965U using Tapatalk |
12-10-2019, 12:29 PM | #7 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Sounds like the ABC wires may not be connected properly from the ESC to the motor, when the sensor is attached it will not function if those wires are not in the right order. Sensorless it won’t matter the order and would work as you described. |
12-10-2019, 01:22 PM | #8 |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
The wire order when running with a sensor wire matters. If you don't have a->a, b->b, and c->c, you can cause the ESC to fail.
12-11-2019, 09:48 AM | #9 | |
| Mamba X problems Quote:
Well that was it, I sent my car to the shop to get some cables soldered and they altered the order. Still I had some sensor problems but I did a reset to factory settings and it is all done. Thanks to everyone. | |
09-14-2021, 11:07 AM | #10 |
Newbie Join Date: Aug 2021 Location: US
Has anyone ever had pens break where the RX wire plugs into the ESC. ( Mamba X ) Sent from my moto g fast using Tapatalk |
Mamba X problems - Similar Threads | ||||
Mamba Max problems!! Please help! | orientalgunz_00 | Electronics | 8 | 03-29-2012 06:59 PM |
mamba max Problems!!!!!! | boost_aholic97 | Electronics | 9 | 08-28-2008 08:19 AM |
mamba problems | crawler4lif3 | Electronics | 2 | 08-01-2008 10:10 PM |
problems with a mamba 25 | havik | Electronics | 6 | 07-22-2007 10:07 AM |
Mamba problems...Please advise! | Nicklepimp | Electronics | 4 | 06-21-2006 05:39 PM |
