01-02-2020, 09:22 PM | #1 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Help with my HW 1080 please??
So last week it's fine, Tuesday went out for a crawl,rx switched on, then the esc, beep beep beep,then a sec goes by(2 or 3secs give or take) then the last beep. I have no idea why it did that, i was thinking,rebind the esc to the remote again? Turned it on, again same thing, unplugged the battery,just to see what happens,plugged it back together hit the on button, same beep beep beep a puase i hit the trigger,last beep/engaged/working, After i hit the throttle that's when the last beep went off?? What gives? My drag brake is not like it use to be.......(im thinking its the HH torque master motor,the brushes,and just a big guess) Batterys fully charged, rx battery fully charged,maybe the motor connectors aren't touching correctly? I've had this ESC however long it's been out for,1st batch of these i bought. I'm stuck guy's,have no idea why it takes time for the last beep to beep. Anyone expierence this? Again,many thanks. |
01-02-2020, 09:33 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Help with my HW 1080 please??
I'm getting the same problem since my last 3 or 4 crawl sessions. I get my 3 beeps for the LiPo then nothing. My servo works fine but I get no throttle. If I reset the ESC a few times it work but I can see it's back to the stock programmation, not my custom settings. I can also fix it by powering the ESC BEFORE the radio which is not supposed to be a good thing. I will do a full rebind and recalibration when I open the bomber for the winter maintenance. I'm too lazy to open the damn cage... Sent from my Pixel 2 XL using Tapatalk |
01-02-2020, 09:33 PM | #3 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
What does the manual say regarding the sequence of beeps?
01-03-2020, 06:53 AM | #4 |
This is odd. Did you try recalibrating the ESC using the button on the power switch?
01-05-2020, 03:12 PM | #5 |
Pebble Pounder Join Date: Jun 2018 Location: New Zealand
Sometimes my last beep takes a few seconds. It seems completely random. The servo still centers as soon as I turn on the ESC but no throttle until that last beep.
01-05-2020, 04:56 PM | #6 |
| Re: Help with my HW 1080 please?? |
01-05-2020, 07:47 PM | #7 |
Help with my HW 1080 please?? - Similar Threads | ||||
Русские идут (the Russian is coming) - our ironworker goes Scale... | nicodrive01 | Scale Videos! | 8 | 05-07-2011 10:33 PM |
