03-01-2020, 05:08 PM | #1 |
Rock Crawler Join Date: Feb 2010 Location: costa rica
| Problem with brushless setup
Ok I have a brushless motor that works with no load... As soon as it has some resistance it stalls... Is it the motor or the esc? Running it at full speed no load it gets extremely hot... Over 215 degrees... https://youtu.be/h_X7ad5Mx_0 Let me know your thoughts Inviato dal mio SM-N9600 utilizzando Tapatalk |
03-01-2020, 05:20 PM | #2 |
| Re: Problem with brushless setup
Lots of questions to be asked. What motor is it? Is it sensored or sensorless. Which ESC? What battery? I'm guessing the motor is just shot if you let it get to 215 degrees... Typically it's recommended that a motor stay under 160F. |
03-01-2020, 09:22 PM | #3 |
Chinese generic junk from the looks of it, quality parts last longer, and perform better. No offense intended, but I would toss it in the trash. Depending on what its going in just get a cheap trailmaster and a hobbywing 1080 for $60 if you want to spend less than $160. |
03-02-2020, 08:33 AM | #4 | |
| Re: Problem with brushless setup Quote:
03-02-2020, 08:59 AM | #5 | |
Rock Crawler Join Date: Jan 2012 Location: Vitoria-Gasteiz
I hate servos or tires fron aliexpress .... Cheap is usually expensive in the end | |
03-02-2020, 10:23 AM | #6 | |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
Once the magnets get overheated once they lose some magnetism, which means they pull more power to spin the motor, which means they got hotter, which means they overheat again and lose more magnetism, and it goes on and on progressively getting worse and worse each time. * This is why it's important not to overheat BL motors.. | |
03-02-2020, 10:53 AM | #7 |
Ok so it's the motor. Well at least I know what it is. Thanks for the help everyone.. Inviato dal mio SM-N9600 utilizzando Tapatalk |
Problem with brushless setup - Similar Threads | ||||
twin FX-R setup problem | Daddydancool | Electronics | 6 | 02-16-2011 09:04 PM |
A setup problem | insane | Electronics | 1 | 08-05-2008 02:01 AM |
