Thread: Futaba 3PK issues with compatibility with Hitec 645s
Old 02-24-2007, 11:01 AM   #1
Default Futaba 3PK issues with compatibility with Hitec 645s
Running a Novak Super Rooster, Futaba 3PK radio, and Hitec 645 servos. Everything is hooked up properly, to my knowledge. When I power up the ESC everything is fine, but when I power up the radio the servos jerk to one side and don't respond. I've tried adjusting the end points but this doesn't seem to help. What am I doing wrong?
WillyP is offline   Reply With Quote
Old 02-24-2007, 11:07 AM   #2
DaViolentOne's Avatar
Sounds like it could be a centering issue... Have you set the centers on the radio and the servo's to center? I'm not familiar with the radio but I do know yo can tweak the centers a bit...
Altho it sounds like your trims could be off, too... Center everything up... Trim and EPA as well as radio center points... That may help...
DaViolentOne is offline   Reply With Quote
Old 02-24-2007, 11:13 AM   #3
Thanks. I'll give it a try and probably be back for more help.
Old 02-24-2007, 12:03 PM   #4
RC4WD Team Mgr/W.Pa.C.
Rckcrwlr's Avatar
I ran that same combo and never had an issue. I agree that it could be a centering issue or interference from a wire????
Rckcrwlr is online now   Reply With Quote
Old 02-24-2007, 12:09 PM   #5
Centered everything up and it works just fine. I think I've got to much radio for my skill level. Too many different settings. I imagine it would be great for someone who knew what they were doing though.
Old 02-24-2007, 12:16 PM   #6
Good to hear ya got it all straightened out and glad I could help.. I, myself, have never owned or used a radio with more than dual rate on it...;) I just know enuff ppl with them to have a grasp of what they can do and so on...
Old 02-24-2007, 12:18 PM   #7
Rckcrwlr's Avatar
It is a great radio. It is best for Racers and specifically Nitro racers. I had one but then sold it when I got into crawling. All you need for this hobby is a 2 or 3 channel radio. No frills. I am running a DX3 now and it is perfect. Others are running things a simple as a TQ3.
Read the book with the 3PK. It is pretty easy to use. Just keep it on Level 1.
Good Luck.
