07-23-2020, 07:37 AM | #1 |
Quarry Creeper Join Date: Apr 2008 Location: San Diego
| Mamba X 3800 issue
I have a trx4 that I installed a Mamba X 3800 “Crawler Edition” combo. It’s been ran 3-4 times and worked excellent. No problems at all. Today I went to program it with the B-Link and it gives me 2short beeps and one long beep. It not hot since it hasn’t been ran in a few days and my condo is kept pretty cool. I’ve tried using b-link to reset programming and are sure the thermo shut down is off (default setting). What am I doing wrong here? |
07-23-2020, 08:02 AM | #2 |
| Re: Mamba X 3800 issue
2 short beeps followed by a long beep (along with all ESC lights flashing) indicates the ESC is not getting a radio signal from the receiver. Double check the ESC is plugged into the receiver correctly and the receiver is getting power. Even the most experienced among us is not above plugging in a receiver plug the wrong way from time to time. |
07-23-2020, 08:08 AM | #3 | |
| Re: Mamba X 3800 issue Quote:
I can steer and use all the micro servos no problem. Only throttle is disabled. | |
07-23-2020, 08:39 AM | #4 |
| Mamba X 3800 issue
If plugged correctly, recalibrate Tx and Rx On Castle ESC’s the LEDs tell you what wrong. Here’s old reliable! https://rogershobbycenter.com/castle...eshootingguide Hang up and Drive |
07-23-2020, 09:39 AM | #5 |
Also I’m an idiot and read the guide as - - • being short short long instead of long long short. You guys are probably right and I didn’t plug something in correctly. Hoping I can get it going when I get home. Thanks for the quick responses. I’ll update tonight. |
07-24-2020, 07:43 AM | #6 |
Ended up being the receiver. Pulled the traxxas receiver and put in a futuba system I had and it works perfectly fine.
Mamba X 3800 issue - Similar Threads | ||||
Mamba X issue | mewalsh100 | Electronics | 17 | 11-14-2018 02:33 PM |
Mamba Max SCT w/ 1410 3800 sensorless | Lukefalls | Electronics | 2 | 04-03-2012 09:52 PM |
Mamba Pro and Tekin 13.5 issue | boulder | Electronics | 10 | 11-12-2011 06:10 PM |
help! mamba max issue | Mac10 | Electronics | 4 | 01-11-2008 07:50 AM |
mamba max issue | rockwerks | Electronics | 14 | 07-11-2007 07:34 AM |
