Thread: Brushless the way to go ...
Old 02-24-2007, 03:13 PM   #1
Default Brushless the way to go ...
I am looking for a ESC and a motor for my TLT crawler.
I see that there are a lot of Integy motors used for a crwaler, but i am thinking about some thing else.
I have layed a eye on the Novak Crawler Brushless Motor System, is this the way to go crawling
Any one with experiance with the brushless set ?
greets from the Netherlands
SXV 550 is offline   Reply With Quote
Old 02-24-2007, 03:31 PM   #2
RC4WD Team Mgr/W.Pa.C.
Rckcrwlr's Avatar
Not a second thought...Go with the Holmes RR2 with the Mamba 25. You cannot go wrong. Smooth power with a ton of torque. Look him up in the vender section or a Holmeshobbies.com.
Rckcrwlr is offline   Reply With Quote
Old 02-24-2007, 03:38 PM   #3
if you want to use it for more than just crawling, occasional running or bashing, go with the crawler. its got killer low end torque and awesome topend. make sure you get the revised one however, though if you dont you can send it back to novak for updating. i got 2 i am waiting for to come back, they are awesome systems and revised should be wicked awesome.
Thorsteenster is offline   Reply With Quote
Old 02-24-2007, 09:07 PM   #4
TEAM MODERATOR
Reflection's Avatar
Hands down,Holmes Hobbies. You won't beat John's customer service and prices. IMHO,the Mamba Max is thee best crawling ESC. Allot of guys run the Mamba 25 in a 2.2 sized rig,but I'd prefer the Max. I've got both of them and both are nice units. The Max actually has a case with heat sinks and is more robust than a 25.
Reflection is offline   Reply With Quote
Old 02-24-2007, 09:17 PM   #5
Brushless generally means you can run smaller motors with higher voltage. Both of which are great for crawling.
However, I didn't like using the Mamba 25 in my TLT SW2 because the BEC only had 1.5 amps and had a hard time turning the front wheels on my crawler (They are big IMEX All-T's though).
So I switched to a Quark 33 and am finding the results to be better, but there are still a few bugs.
In the end if you can afford it the Novak crawling system will likely end up being the best out there, but the Mamba Max ESC (can run both brushed and brushless) with an outrunner motor could be an awesome combination.
Brushless gives good speed, great torque and light weight. It's still a little new, but will only get better.
Wookiebiker is offline   Reply With Quote
Old 02-24-2007, 09:31 PM   #6
Mamba max is worth every penny over the mamba and the quark in my experience. Plus you can run yourself a brushed motor if you want and have silky smooth startup power if your pocketbook can't handle both brushless and that esc at once.
Cloak is offline   Reply With Quote
Old 02-24-2007, 11:14 PM   #7
Thumbs up Mamba Max.....
I've had experience with a couple but i do feel castle creations mamba systems are excellent they work well also have great customer support and of course are an american based co.....
Also they're online support alway's seem's to be enough to answer any questions i have when installing or setting them up so i woul's highly recomend any mamba setup!
Marty
madmarty is offline   Reply With Quote
Old 02-24-2007, 11:50 PM   #8
Hands down mamba 25 esc and Holmes Hobbies RR2. I run this set up in my SW2 with 86 spur 13 pinion on a stampede tranny with a 3 cell 2480 lipo and it rocks. I also run my steering servo and servo for my front dig steer with a seperate small 6 volt 1200 mah rec. battery pack helps out when you run this when useing a steering servo with 330 oz in of torque.What ever you pick have fun with it lol!
draven is offline   Reply With Quote
Old 02-25-2007, 08:33 AM   #9
I have orderd teh Novak @ Towerhobbies, now have to wait for 10 till 30 days or the shipping.
@ thorsteenster: Quote"make sure you get the revised one " how do i see that its a revised version ?
Old 02-25-2007, 08:49 AM   #10
im not sure if theres a way or not by looking at it. email novak, they should be able to tell you. if you can i would cancel my order with tower and maybe buy direct from novak, that should definately be the revised edition. may cost a little more but it would be worth it not having to send it back and waiting for it to get updated.
Old 02-26-2007, 01:53 AM   #11
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I guarantee you will like the novak system Its all kinds of fun and speed for a crawler. I cant wait to get a revised one in.
JohnRobHolmes is offline   Reply With Quote
Old 02-26-2007, 09:33 AM   #12
i hope to have mine back this week or next. i got 2, one i'll put a sintered rotor in for a crawler and the other more for a runner.
Old 02-26-2007, 02:34 PM   #13
I am all new into the brushless, what is a sintered rotor.. balanced or something ?
Old 02-26-2007, 02:36 PM   #14
More powerful magnets.
Old 02-26-2007, 03:14 PM   #15
that sintered rotor is mega magnetic, anything with in a 5' radius of it gets sucked into it
Old 02-27-2007, 03:35 PM   #16
Ok thanks for explaning
Old 02-27-2007, 10:16 PM   #17
i have a mamba max and am hoping to get a tlt sw2 chassis. what would be a good motor for casual and comp. crawling with this rig?
theTman is offline   Reply With Quote
Old 02-28-2007, 12:50 AM   #18
A motor that is at least 3.5 ounces IMO, if you are wanting comp use too. An eflight park 400 would work pretty good, but something larger like a hyperion z3013 or any other 28mm (power 10, himax 3516, mpjet 2810, stator motor gives a ton more torque.
Old 02-28-2007, 05:14 PM   #19
so would the hyperion z3013 be good enough, or should i go with the z3025-08 which has more power?
Old 02-28-2007, 05:38 PM   #20
TEAM MODERATOR
Reflection's Avatar
Chances are,with the 3025-8,you'll rip those TLT axles to shreads. IMHO,it's a great motor for supers if you've got near bomb proof axles. Trust me,it IS a HOSS. You'll notice looking around,most guys with 2.2 and TLT sized rigs will be running the smaller outrunners. The TLT's I've seen run with the smaller Hyperions are PLEANTY stout enough.
