07-26-2020, 04:49 PM | #1 |
Pebble Pounder Join Date: Feb 2020 Location: ascutney
| waterproofing
anyone use corrosion x on their electronics for waterproofing? if so does it work or any other suggestions aside from buying waterproof lol Sent from my iPhone using Tapatalk |
07-26-2020, 05:02 PM | #2 |
| Re: waterproofing
i tryed it a few times it seems it would work for 1 dunking the second time it goes under it would fry servos seemed to hold up better than escs i think it more stopes the corrosion after the dunking than waterproofs it |
07-26-2020, 05:11 PM | #3 | |
| Re: waterproofing Quote:
right on thanks for the feedback, i saw a few similar answers on the reviews Sent from my iPhone using Tapatalk | |
07-26-2020, 05:18 PM | #4 |
| Re: waterproofing
Corrosion X wears off, quickly. I use conformal coating, I have never had a failure. The main thing I use it on are my CC BECs. I take off the heat shrink, and dunk the BEC three times, letting the coating dry about an hour between dunks. I put the heat shrink back on and its good to go.
07-26-2020, 05:32 PM | #5 | |
right on, i'll try that on mine, was hoping for something to spray on for a receiver but may just have to end up getting a low profile waterproof box Sent from my iPhone using Tapatalk | |
07-26-2020, 07:55 PM | #6 |
Rock Stacker Join Date: Jan 2017 Location: Chicago
| Re: waterproofing
I have used both conformal coating and Corrosion X. I have had the electronics in my Bomber coated with Corrosion X for about 4 years. No issues with anything but the freaking switch on the Mamba X. But the switches are always the weak link. I used the spry on conformal coating on my kids rig. Everything worked great. Never had an issue as with the Corrosion X. Until I went to use the spray can again. Even though I cleaned the nozzle, it still got pugged up with the material. I found the $20.00+ price tag was not worth a one shot application. My $.02, |
07-26-2020, 09:17 PM | #7 |
| Re: waterproofing You could likely take the RX out of the case, coat it, then put it back. You'll need to cover the pins, the conformal coating will also insulate the pins.
07-27-2020, 06:33 AM | #8 | |
really, just one coat so i don't ruin it?, makes me nervous with the pins, but i like the idea with the box, i'll have to give a try, i have 2 extra so if need be and it doesn't work atleast i've tried, thanks for the idea! Sent from my iPhone using Tapatalk | |
07-27-2020, 06:34 AM | #9 | |
yeah it is expensive even for a 6oz can, but i like that you had luck with it, still tryin to figure a route i wanna take but all about trial and error by the sounds! Sent from my iPhone using Tapatalk | |
07-27-2020, 08:01 AM | #10 |
| Re: waterproofing
super glue makes a great waterproof coating i do 2 or 3 coats with th3 superglue and havent had a failure yet but i never tryed it on a esc just becs servos and recivers winch controlers light controlers little stuff
07-27-2020, 09:39 AM | #11 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: waterproofing
Conformal coating is by far the best option. imo, it's the only thing anyone should be using to waterproof pcb's at all. Epoxies and CA glue can work well too but you have to be careful not to get something that has conductive additives in it. If the nozzle clogged after one use I hate to be the guy that points it out but that's user error and can't really be called the fault of the product. I used a spray can of conformal for about 2 yrs until it was empty without issue. After that spray can was done I switched to the bottle and I use the applicator brush instead. I find the brush-on works much better - the spray can often created air bubbles in the coating that could become failure points if not dealt with. For both the spray or the brush-on I always do at least 2-3 coats. I treat my rigs like submarines and I've only ever had one of waterproofed Rx's fail once in about 5-6 years. I use this treatment for any pcb's that need water protection - Rx, BEC, ESC, Switches, winch controllers, etc... *Don't forget to also use dielectric grease on/in all of the connections points too - it keeps the pins and plugs from corroding. |
07-27-2020, 09:43 AM | #12 | |
I always recommend 2-4 coats just to ensure you've got it everywhere. Also, most conformal glows under UV so if you have a black light you can use to check the coverage. | |
07-31-2020, 04:56 AM | #13 |
Newbie Join Date: Jul 2020 Location: califonia
| Re: waterproofing
Thanks for your great information i helps me alot.
waterproofing - Similar Threads | ||||
waterproofing | JtsYfz450 | Electronics | 2 | 01-29-2012 01:20 PM |
waterproofing | The Bandit | Axial SCX-10 | 16 | 06-25-2010 06:14 PM |
waterproofing | axialartr | Newbie General | 3 | 02-11-2009 10:24 PM |
waterproofing help | 4x4wheelier | General Crawlers | 1 | 12-24-2008 09:34 AM |
Waterproofing?.. | InFlames | Losi Mini-Rock Crawler | 2 | 11-03-2008 09:31 PM |
