Thread: Good budget servo for TRX4?
Old 07-29-2020, 11:14 PM   #1
Default Good budget servo for TRX4?
Just as the title says, what’s a good cheap servo for a trx4? My 2075 is locked up and I don’t know what’s going on. I don’t care if it’s not waterproof, I can waterproof it myself. TIA
ScaleLifeNewbie is offline   Reply With Quote
Old 07-30-2020, 07:57 AM   #2
Default Re: Good budget servo for TRX4?
https://www.amazon.com/Power-HD-Wate.../dp/B07Q6BWTYQ
Greatscott is online now   Reply With Quote
Old 07-30-2020, 12:19 PM   #3
Fricker08's Avatar
https://www.amainhobbies.com/ecopowe...RoCuOgQAvD_BwE
I personally run savox 1210sg in all my rigs. But I’m running 7.4v
Fricker08 is online now   Reply With Quote
Old 07-30-2020, 12:21 PM   #4
Inspector86's Avatar
I'm running the Savox 1230SG in all of my TRX4s, a couple of the trucks have over 1000 hours of run time without a servo failure. The 1230SG is rated at 500 oz in at 6v making it a nice fit for the TRX4 electronics. At $72 it is not the cheapest but I have two that have over 1000 hours which makes it a good value.
Inspector86 is offline   Reply With Quote
Old 07-30-2020, 01:09 PM   #5
Savox !
You get what you pay for.
Uncle Pete is online now   Reply With Quote
Old 07-30-2020, 02:49 PM   #6
Yeah, I was looking at the Ecopower one yesterday.
Old 07-31-2020, 05:33 AM   #7
Originally Posted by Uncle Pete View Post
Savox !
...yeah and more ! Noise , crappy customer service , etc
i have this ..economic, steel gears, coreless ,fully waterproof, 32kg
[IMG][/IMG]
https://de.aliexpress.com/item/40000...52ee2e0eowcRkQ
themountain is offline   Reply With Quote
Old 08-04-2020, 11:28 PM   #8
I’ve used this one to good effect https://www.amazon.com/Jiexin-LuckyS...s%2C182&sr=1-5
JimInMiami is offline   Reply With Quote
Old 08-06-2020, 12:58 PM   #9
i had a budget high-torque servo from amazon. its specs seemed to be reaching farther than it could deliver. then tried a Savox 1210. still not impressed and the constant noise bothered me. Now i have a HH v3 and its still loud, but i my rig finally has a servo with enough umph. So just go for a good quality or spend more trying to find a cheap one that works for you.
splyn is offline   Reply With Quote
Old 08-06-2020, 01:23 PM   #10
Originally Posted by splyn View Post
.. then tried a Savox 1210. still not impressed and the constant noise bothered me.
https://youtu.be/tjgih7qZTpk
Old 08-06-2020, 05:27 PM   #11
Aloha! I ended up buying the Savox SC-0252 for $35 on AMain. Hopefully it will last a while. Yes, ik it’s not even close to being the best, but I just want a cheaper one until I can get a Savox 1210
Thank you guys for all of your help in my purchase of a Savox! Will provide an update when she gets here on the 10th
Old 08-06-2020, 05:43 PM   #12
Savox 1230 TRX4 Defender
Old 08-06-2020, 05:50 PM   #13
I was thinking about the 1230 too. I have a trx4 Bronco with a Jeep Wrangler body and 2.2s (my tranny doesn’t like me)
Old 08-06-2020, 10:06 PM   #14
I got the savox 1210sg also does the job quite will and keeps up rain shine snow mud ect keeps on trucking
89lxmorepower is offline   Reply With Quote
Old 08-07-2020, 05:37 AM   #15
Originally Posted by ScaleLifeNewbie View Post
Aloha! I ended up buying the Savox SC-0252 for $35 on AMain. Hopefully it will last...yadada...
Some people you cant help.
Old 08-07-2020, 11:55 AM   #16
Sketchiness abounds...
durok's Avatar
I'm currently testing this one in my Defender TRX-4:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
ANNIMOS 35KG Coreless Digital Servo Motor 7.4V High Voltage Stainless Steel Gear High Torque Waterproof
Operating voltage range: 5-7.4V
Operating speed ( 5.0V ): 0.1 3sec/60 degree
Operating speed ( 6.0V ): 0.12 sec/60 degree
Operating speed ( 7.4V ): 0.11 sec/60 degree
Stall torque ( 5.0V ): 29kg/cm
Stall torque ( 6.0V ): 32kg/cm
Stall torque ( 7.4V ): 35kg/cm
I have a DS3218 in my Ascender that's still going strong after a couple years and a DS3218 Pro in my Enduro (slightly faster/stronger).
My Bomber has a Holmes SHV500 v1, and I have a ProModeler PM470 for Bomber build #2....
It just depends on the weight of the rig and the size of the tires - I'll usually run a budget servo on a 1.9" trail truck. If I find they continually give me issues I'll upgrade - but so far so good. I have wrecked several RTR servos...
durok is online now   Reply With Quote
Old 08-07-2020, 02:58 PM   #17
Moderator
JatoTheRipper's Avatar
We have an entire thread for this. PowerHD isn't bad, but I think they are overrated. I have a couple myself and they don't have the power that they claim to have.
What the newest cheap servo hotness?
Old 08-07-2020, 04:33 PM   #18
You could have just bought a stock servo instead...
HugoBiermann is offline   Reply With Quote
Old 08-07-2020, 07:26 PM   #19
Irrelevant comment. If you don’t like it, move on.
Old 08-07-2020, 07:27 PM   #20
Annnnddd your point? Why spend more $ for a cheaper servo?
Tags
trx 4, trx4 servos
Good budget servo for TRX4? - Similar Threads
TRX4 Budget 4s Lipo 5 Slot Motor Testing. Hardcoretam Videos! 0 04-23-2020 10:20 AM
Whats a good budget servo choice? big_poppa49 Axial SCX-10 25 11-22-2015 06:44 PM
What is a good budget servo? Benjamin Axial SCX-10 3 01-23-2013 10:58 PM
Good but still budget motor cornel4web Electronics 4 10-25-2010 04:47 AM
Good budget esc steff_13 Electronics 0 10-21-2007 05:47 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
