Thread: Radiolink RC4GS failsafe setting help
Old 08-08-2020, 09:28 PM   #1
Default Radiolink RC4GS failsafe setting help
I have read the manual, but not sure what I am reading- hope someone can help this old geezer out. I try and keep a good eye on my truck BUT this radio has the setting so why not use it right? Thanks in advance- Vic in SoCal
oldblue2010 is offline   Reply With Quote
Old 08-08-2020, 09:45 PM   #2
Default Re: Radiolink RC4GS failsafe setting help
I dont have this radio but a failsafe is the state the RC goes to when it loses signal or you turn your radio off. They used to runaway when this happened.
I would assume leaving all of these values at zero would be what you'd want. This should keep the RC from running away.
Though as long as you turn off your radio last you dont need to worry about this since losing signal is not an issue anymore.
HumboldtEF is offline   Reply With Quote
Old 08-08-2020, 09:57 PM   #3
The truck will be out of sight way before you lose signal from the radio.
I went FPV and could still control my truck 300+feet away looking at the camera feed only, it was out of sight completely
Sent from my Pixel 2 XL using Tapatalk
Jboucher is offline   Reply With Quote
Old 08-08-2020, 10:00 PM   #4
It was more for nitro as they did not have a esc so if it lost signal it could be stuck at that throttle setting and you no longer have control of it.(Runaway) until it ran out of fuel or wrecked
Sent from my SM-G973W using Tapatalk
jaymann is offline   Reply With Quote
Old 08-09-2020, 09:13 PM   #5
Greetings Humbolt and the board- yeah I'm gonna turn the radio off first from now on BUT someone said about the failsafe and I found it on the radio and idle hands you know the rest haha- thanks for the responce- and yup this will be the last time I worry about it- Vic in So cal
Radiolink RC4GS failsafe setting help - Similar Threads
Radiolink RC4GS oldblue2010 Electronics 6 09-13-2020 01:25 PM
Radiolink RC4GS battery info wanted oldblue2010 Electronics 1 05-30-2020 07:25 PM
info wanted on Radiolink RC4GS oldblue2010 Electronics 6 04-24-2020 11:45 AM
Hobbywing 1060 has no failsafe?! QuesoDelDiablo Electronics 20 11-25-2016 12:39 PM
This must be the reason for a failsafe slugzracing Chit Chat 23 06-16-2007 10:54 AM
