08-03-2020, 02:06 PM | #1 |
Newbie Join Date: Apr 2020 Location: New Hampton
| Savox 900oz servo |
08-03-2020, 02:15 PM | #2 |
Pebble Pounder Join Date: Jan 2018 Location: Northeast Iowa
| Re: Savox 900oz servo
i use the 2290 on my bomber. absolutely love it. best servo ive ever owned. its super robust Sent from my SM-G965U using Tapatalk |
08-03-2020, 02:52 PM | #3 |
The 2290 is a beast, but this one appears to be waterproof. This one also appears to accept more voltage and it gives you more power! Good find! |
08-03-2020, 03:06 PM | #4 |
Only Savox I admit to owning. It resides in Opie , my 11.5 lb Wraith. So far it’s the only servo to survive! Hang up and Drive |
08-03-2020, 04:34 PM | #5 |
RCC Addict Join Date: Jun 2008 Location: Mudville
900 at 8.4 is a brute. I wonder how close their ratings are. Francis from RC Review should put this on his test system. It shows the real world torque pulled. |
08-03-2020, 04:42 PM | #6 |
What I can easily say is I replaced a Holmes SHV with the 2290 after multiple failures (torn gears) and it’s still running 2years later Hang up and Drive |
08-03-2020, 09:51 PM | #7 | |
| Re: Savox 900oz servo Quote:
The published 902oz of torque explains why I can't tell much, if any, difference between the 2290 and the 1027oz (at 7.4v) of my Futaba A700, both solid, but I'd just go with another 2290 if I were doing it over again. I'm about due for a new case (mounted behind my front axle so the case gets drug over rocks and is getting pretty thin) on mine, so I'm hoping the waterproof case set (I'm assuming it's got o-ring grooves machined into it?) will fit, and be available soon. | |
08-04-2020, 12:27 AM | #8 |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
Damn... 10.5amps at 8.4v at stall. If you were at stall for very long you could melt your servo plug. They are only rated for a few amps continuous. Honestly at that power level they should have just made the servo take pack voltages like HH's servo does. To run that properly you need a hella beefy BEC, even our normal CCBEC can't keep up with that. You would need a BEC Pro or BEC 2.0 just to power that thing.
08-04-2020, 01:31 AM | #9 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
Love my 2290s. Match them with a BEC 2.0 and they'll break fingers if you're not careful. |
08-04-2020, 01:31 AM | #10 | |
10a will brown out, 2.0 14a works great. | |
08-04-2020, 10:33 PM | #11 |
Rock Stacker Join Date: Feb 2017 Location: United States
Wow, 900 oz-in? Kinda overkill ain't it? |
08-04-2020, 10:45 PM | #12 |
| Re: Savox 900oz servo |
08-05-2020, 01:12 AM | #13 |
Quarry Creeper Join Date: May 2017 Location: Devon
Wish they'd spend some R+d on making them quieter. My 2290 is constant Sent from my Pixel 3 using Tapatalk |
08-05-2020, 02:13 AM | #14 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
08-05-2020, 02:18 AM | #15 |
08-05-2020, 05:58 AM | #16 |
Quarry Creeper Join Date: Dec 2013 Location: The Garden State, North of I-80
So lets's exaggerate the servo arm to be 2 inches. That means the servo can lift/push 450 oz. That's 28 POUNDS! Of course that's exaggerating the servo arm to be 2 inches. Anything less will only make that 28 pounds larger. We really need more than that for our 1/10 purposes? |
08-05-2020, 07:13 AM | #17 | |
Yes IF you run large 2.2 tires , have a heavy rig , and want to pop it out of crevices. DLux also makes a geared up version as a add on for super comps. Hang up and Drive | |
08-05-2020, 08:34 AM | #18 | |
Sent from my SM-G965U using Tapatalk | |
08-05-2020, 10:22 AM | #19 | |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
I like that move! Going to have to try it! Is there a specific servo horn you run for handling that type of use? I got a chuckle when I saw your hat. Thanks ETA - Anyone have any ideas why more companies don’t offer direct power servos. Seems like it would make for simpler solutions by eliminating the need for good esc and/or a bec to run a higher output. Is it just that the rc segment that would use these too small to justify production? Last edited by Benp; 08-05-2020 at 10:47 AM. | |
08-05-2020, 12:04 PM | #20 |
Savox 900oz servo - Similar Threads | ||||
Savox 1230 servo what size servo arm? | Jettcity1 | Axial RR10 Bomber | 2 | 05-08-2019 01:04 PM |
Savox servo issues with Vanquish servo horn... | Drm31078 | Electronics | 13 | 01-29-2017 06:53 AM |
Savox servo | Bogncrawl | Electronics | 8 | 02-17-2013 08:25 PM |
