Thread: y adapter q's
Old 02-25-2007, 12:26 PM   #1
Default y adapter q's
http://www2.towerhobbies.com/cgi-bin...?&I=LXHFN4&P=7
will this work with any servo say the tower pro ones ? ? ?
just wondering if all servo conectors are the same
thanks
chivas72 is offline   Reply With Quote
Old 02-25-2007, 12:32 PM   #2
servo connectors are different. Hitec, Tower hobbies, Hobbico are all the same, Airtronics has the z connector and futaba has the J connector. If the servo you want to use the harness with has red,black and yellow wires it is most likely a hitec connector and you can use this harness:
http://www2.towerhobbies.com/cgi-bin...?&I=LXUR74&P=7
EastCoastCrawlers is offline   Reply With Quote
Old 02-25-2007, 12:39 PM   #3
i'm gonna use two tower pros like the ones run2jeepn and double j sell
which one do i use ? ? ?
Old 04-02-2007, 11:29 PM   #4
I have Tower Pro Servos plugged into standard Futaba Y Harnesses, they fit just fine, the tower pros just don't have the little index tab that futabs do. so you can plug them in backwards by accident unlike the futabas which can't. That harness will work perfectly for you.
Rob92k1500 is offline   Reply With Quote
Old 04-03-2007, 10:40 AM   #5
Run2jeepns hooked me up with one and i also bought a reversing y from holmes hobies
thanks for the tips and helps guys
