Thread: Building help
Old 02-25-2007, 01:45 PM   #1
Default Building help
Hello, I am building a rock crawler and I have a few questions (I searched around and couldnt find what I wanted)
1) Can I use the Ko Propo EX-10 for rear wheel steering ? if so is it full steering or just a switch.
2) can I combine 2 ESC's BEC's so I can have 6 amps of current for the servos(they each have 3 amps each).
Thats it thanks for the help.
captaincrawler is offline   Reply With Quote
Old 02-26-2007, 08:03 PM   #2
Please, I could use some help on this
Old 02-26-2007, 10:24 PM   #3
I don't know anything about that Tx. What ESC's do you have and what are the spec on them besides the BEC?
scruff007 is offline   Reply With Quote
Old 02-27-2007, 06:49 PM   #4
I am running two mamba max systems, am thinking maybe a simple y harness would do it? or would this not work.
Old 02-28-2007, 01:36 AM   #5
I don't know much about the Mamba ESC's. I would PM JohnRobHolmes about it. He's the guru of brushless systems.
