Thread: Servo Saver ??? Maxx Crawler
Old 02-25-2007, 02:33 PM   #1
Default Servo Saver ??? Maxx Crawler
Ok guys will using a servo saver help me from burning up servos I was running xtm servo cirrus p-cs704mg and burned it up.(not the gears) Bad servo or dose it need a servo saver? I'm going to replace it w/ hitec 645.
I'm using traxxas TQ3 no end point adjustments.
what servo saver should I get??
tapped-out is offline   Reply With Quote
Old 02-25-2007, 04:39 PM   #2
Keep it real
Tanis's Avatar
In a maxx, the 645 gears aren't going to last long. In our tlt, the gears didn't last long. If you run a servo saver, your tires won't turn in a bind, the saver will unload.
Tanis is offline   Reply With Quote
Old 02-25-2007, 07:09 PM   #3
For a Maxx you should get a Hitec HS-5645mg servo. They have 164 oz of torque. But if you want to go all out and get the best of the best, get a HS-805bb 1/4 scale servo. These servos have 343 oz of torque!! Hope this helps, and good luck with your Maxx!
Krystopher
Toph is offline   Reply With Quote
Old 02-25-2007, 07:17 PM   #4
Keep it real
Tanis's Avatar
The 645 and 5645 have the same gears. I have heard good things about the 805.
Old 02-25-2007, 10:28 PM   #5
Hs-805 any one have any pics of it mounted on a maxxcrawler?
and do you guys think this should be the last servo for this truck or will it break also.
thanks
tapped-out
Old 02-25-2007, 11:50 PM   #6
Colt Python/SR9c
TwistedCreations's Avatar
If your looking for the last servo you will ever buy, Airtronics 359 is your answer
I won't buy anything less from now on
TwistedCreations is offline   Reply With Quote
Old 02-26-2007, 12:22 AM   #7
get the Hitec 5955 Titanium Gear Servo i have one in my tlt and its super fast and at 333 oz in. of torque whats their to complain about?
Krawler Freak is offline   Reply With Quote
Old 02-26-2007, 06:41 AM   #8
hey is this the servo your talking about Airtronics 94359Z Heat Sink Hi SpeedTorque Servo I'm using traxxas TQ3 receiver no end points will this burn up the servo
Old 02-26-2007, 02:02 PM   #9
Not to hijack but I'm in the same boat so I'm subscribing. Do you have your mounted in the stock configuration?
jham4x4 is offline   Reply With Quote
Old 02-26-2007, 02:38 PM   #10
Yes these servos do have alot of torque, but they cost over $100!! The 805s have 343 oz of torque for only $40 at Tower Hobbies. So you can pay $100 to get 333 oz of torque, or you can pay $40 for 343 oz of torque.
Krystopher
Old 02-26-2007, 08:56 PM   #11
MY SERVO IS MOUNTED LIKE THIS I THINK I CAN MOUNT THE 805 THE SAME (KINDA) BUT I'LL HAVE TO CUT OFF PART ON BULKHEAD WHERE STOCK SHOCK MOUNT GOES AND LOCK A-ARMS ANOTHER WAY??? NOT TO HARD I HOPE.
Old 02-27-2007, 05:55 PM   #12
your also buying quality with that money to so its not going to waste its worth the money IMO
Old 03-03-2007, 03:13 PM   #13
thanks
tapped-out
It shouldn't break or strip or anything of that sort. I would tell you how well they perform, but the rig I have them on is not finished yet. Anyway, here is the pic!!
Krystopher
