Thread: PSA from Holmes Hobbies Regarding Direct Powered Servos
Old 10-15-2020, 09:10 AM   #1
Default PSA from Holmes Hobbies Regarding Direct Powered Servos
I found this HH post on the Book of Faces. I just took a screenshot instead of linking for those that don’t have facebook.
Good info. I was not aware of this and it makes sense.
Benp is offline   Reply With Quote
Old 10-15-2020, 09:52 AM   #2
Default Re: PSA from Holmes Hobbies Regarding Direct Powered Servos
I saw this as well.
I have a few direct power servos that I'll be using soon. I plan to just hook them up like I do with the BEC's on the power leads of the ESC.
soze is offline   Reply With Quote
Old 10-15-2020, 10:39 AM   #3
Tiny Truck Hoarder
HumboldtEF's Avatar
I've always though it was asking for trouble hooking anything (other than a charger) up to the balance leads. Nice to know some details behind it.
Now stop being lazy guys, learn to solder already!
Its also kind of shocking that the balance connectors are only rated for 30 unplug cycles, thats way lower than I would have expected.
Thanks for sharing this BTW
HumboldtEF is offline   Reply With Quote
Old 10-15-2020, 10:57 AM   #4
Gold Star Baby!
Topher Builds's Avatar
Agreed on all fronts ^^
Topher Builds is offline   Reply With Quote
Old 10-15-2020, 11:46 AM   #5
All of it makes sense...except point #3 ("balance taps are only rated for 30 unplug cycles"). Every time you charge your battery, you are plugging-in, and unplugging, the balance connector. By point #3, or airways to be indicating that a battery would only be able to be charged 30x, before the balance connector 'fails', and needs to be replaced...unless I am misunderstanding what point #3 is indicating (and, if so, please explain the "correct meaning" of point #3).
As for using external BECs, the ONLY way I install them is by soldering directly to the ESCs battery connector, and then connect to the RX & servo via a HH Rx Bypass Adapter (Rx dual servo bypass adapter in my Class 3 4WS rig).
Panther6834 is offline   Reply With Quote
Old 10-15-2020, 12:13 PM   #6
Gold Star Baby!
Rated for 30 cycles does not mean guaranteed to fail at 30 cycles.
I’m guessing you’re unlikely to see failure that soon but may observe some wear and a looser connection after that much use.
Old 10-15-2020, 02:15 PM   #7
Thank you for the clarification. As for "looser connection", is that referring to the wires going into the balance connector? Or the balance connector going into the balance board?
If the first one, I probably don't have to worry much about that. I've installed "balance connector protectors" on almost all my batteries (the ones not-yet-done will be done soon enough...just need to find where I placed those 6S protectors). When pulling the balance connector from the balance board, I'm not tugging on any of the wires, as the protectors clip directly to the balance connector, and provide a much larger "grab" area (compared to just the balance connectors plastic).
PSA from Holmes Hobbies Regarding Direct Powered Servos - Similar Threads
RESTOCK Holmes Hobbies Servos! RPP Hobby RPP Hobby 0 05-18-2018 02:05 PM
Holmes Hobbies HV500 & SHV500 V2 Servos - In Stock! RPP Hobby RPP Hobby 0 10-18-2017 11:52 AM
My rock racer test video - Powered by Holmes Hobbies. badger Videos! 28 09-27-2008 10:46 PM
