Tekin rx4 and tekin 440 Hi I wonder if anybody could help me I've set up a tekin in RX4 and 440 servo in my vanquish ultra I also have put a castle 2.0 BEC at eight volts but I'm still getting glitching and a lot of noise coming from the servo any help would be most appreciated many thanks. |
Re: Tekin rx4 and tekin 440 What kind of glitching? The tekin servos are set pretty aggressive on their centering out of the box, might be worth getting a hotwire and turning it down a level. With your BEC, you're using a bypass and not having the rx4 bec fighting the 2.0, right? |
Re: Tekin rx4 and tekin 440 Did you disconnect the red wire from the ESC? I assume the external BEC is routed to the receiver. Whats specifically happening? details will help. I got a defective Tekin servo last year, it had a mind of its own steering on its own and sometimes not responding to input. I think they found that it had a bad board, I sent it in under the warranty. |
