| | #1 |
| Quarry Creeper Join Date: Nov 2006 Location: Rockaway
| I'll try my best to give all the details. I have a futaba 2 ch rx that worked fine up untill today last night I accidentily hookup up the batt wires wrong to the esc and the esc smoked but still worked then today the rx works with the esc but no servos? I hooked the servos up to another radio system and they work fine, if I put the esc in ch 1 it works fine if I put it in ch 2 it works fine but the servos don't work in either with this rx. I also tried changing the crystals just for safe measures. This doesn't make much logic to me but I would guess it's my rx?. |
| Sponsored Links | |
| | #2 |
| I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| have you tried running the servos off a rx pack and not the esc's bec? |
| | #3 |
| Since you just said that I tried it and yes the servos worked when I plugged in a rx pack to the batt plug?. So the rx did take a crap and the power from the esc isn't getting through it? |
| | #4 |
| sounds like you may have fried the bec circut on the esc, try pulling the red wire on the esc and pluging in the esc and servo and try it again |
| | #5 |
| what do you mean by pull it? pull it out of the plug or pull on the circut side or what? btw the motor works fine when plugged in too. Last edited by D-ran83; 02-27-2007 at 08:44 PM. |
| | #6 |
| I pull the red lead out of the connector, to test it. you gently pull back the tab on the connector then slide the red wire out, making sure not to break the tab or else it will never stay on it again!!! by doing this youre eleminating the bec circut from youre esc, temporarily |
| | #7 |
| Pulled it out and I get nothing at all? should I check that wire with a voltmeter? or a test light? |
| | #8 |
| BUMP.. problem still not fixed.. |
| | #9 | |
| Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
The circuitry in The Reciever connects all the positive together, and all the negative together. If you overloaded it, You could take an ohm meter and make sure all the negatives are conductive and all the positive are conductive. If not, then the circuitry needs to be repaired. I am betting your ESC's BEC is messed. Plugin and turn on the ESC only. Volt meter between the black and red wires of the Radio plug. You should get ATLEAST 5 volts. If you do get voltage here is can only be the reciever. Good luck! Now get that chit fixed and go crawlin!!!! | |
| | #10 |
| Yes it works with a rx batt pack should I even bother with the voltmeter check? |
| | #11 |
| every thing works with the rx pack esc work by its self does the esc work with the rx pack and servos?? |
| | #12 |
| didn't try, i'd rather not have the clutter on the rig. So maybe I should just order a esc huh? |
| | #13 |
| i run a rx pack on my esc's to power my digital servos, the bec cant handle them |
| | #14 |
| never heard of that, i'm running 2 standard futaba servos on a 2.2 so theres not much stress. It worked before I fried it! |
| | #15 |
| | #16 |
| O well new rx and esc in the mail so which ever I don't need I can resell is all. Is this bec repairable if I took it to someone?. |
| | #17 |
| I wanna be Dave Join Date: Apr 2005 Location: Kennewick
| You can possibly run a Servo regulator, I dont know which is the best, I Think its novak servo regulator is what people run. |
| | #18 |
| Thanks for all the help, theres a new esc and rx in the mail so whatever I don't need i'll get rid of or hold onto for spare. |
| Thread Tools | |
| Display Modes | |
