08-23-2021, 12:58 PM | #1 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Direct power mini servo winch
Looking for something like this that is direct power that can run on 3s or 4s. I want to be able to mount it laying done on a bumper winch mount, I don't want one that needs a servo mount and no external controller. Is there anything like that out there? Reef 99Micro Servo Winch https://rcnewb.com/small-yet-mighty-...o-servo-winch/ Last edited by MOguy; 08-23-2021 at 01:13 PM. |
08-23-2021, 01:24 PM | #2 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
| Re: Direct power mini servo winch |
08-23-2021, 01:53 PM | #3 | |
| Re: Direct power mini servo winch Quote:
I want a direct power mini I can control with my controller. I suppose I could get one power by the ESC's internal BEC through the receiver if they exist. Right now I am running and SW4 which has a crappy internal BEC but I am thinking about going to a MambaX. The mini's size and mounting on its side is the important part and I don't want to have another component for the controller. Space is an issue. I used that one as example because of the avaialbe mount. I want it to lay it on the winch mount on my bumper. I am able to set the mount part of my bumper back under the body back far enough so it doesn't stick out past my front tires. I want to sit it back where the battery is now on the pic below and the battery will mount opposite side of my ESC. Last edited by MOguy; 08-23-2021 at 01:56 PM. | |
08-24-2021, 04:01 AM | #4 |
Ahh...I understand....you are running 4s in that car? Would it be easier to run a small BEC from the main battery and power the winch servo with that ? A BEC is like 5-10 grams...a second battery is at least 80grams. |
08-24-2021, 07:19 AM | #5 | |
At this time just 3s but I have a MambaX sitting on the bench ready to go in. I can set the MambaX up to more power (not as much as direct power) but I do still have an original TRX. I can replace that mini servo if necessary. I would rather change the TRX mini to one that can handle more power than get an external BEC. The body I have fits tight and with the front SOA set up space is tight up front. There is already more than enough wires in my rig, I don't want more. I have an electric winch on my C1 and I control it with a 3 position switch on my DX5 rugged, I want it set up the same (as far as operation) for my C3 in the pic above. I don not want a separate controller. Last edited by MOguy; 08-24-2021 at 07:41 AM. | |
08-24-2021, 09:31 AM | #6 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
08-24-2021, 10:56 AM | #7 | |
I have given up on the mini, the only one I find is from Reef and it is too weak and not direct power. I am looking into the 3 bros direct power overland winch. I have their direct power servos and they are very good. Their servo winch wires up just like their steering servos. I am planning to mount an axial type servo mount on my winch plate for the winch. By doing this I can lay the servo on its side. I have messaged 3 bros to make sure it is in stock. I will mount a regular servo in the place to make sure I have room to make it all work and if it does I think that is the route I will go. | |
08-24-2021, 03:49 PM | #8 |
What is a direct power servo but a servo that can handle 3s voltages with a different wiring harness? If you can find any servo that can handle 12.4v then just run the power and ground to the battery and the signal to the receiver. if you get a feedback loop then split the ground and run it to both. If you can't find a servo that handles 12.4v then you need to reduce the voltage with a BEC or buck converter of appropriate size. a servo is not much different than an esc, it's just smaller and has a potentiometer to monitor turns. |
08-24-2021, 08:07 PM | #9 | |
08-24-2021, 08:48 PM | #10 |
| Re: Direct power mini servo winch https://rcnewb.com/small-yet-m...unc...o-servo-winch/ Will absolutely run off an internal bec. All it is is a servo with no endstops so it keeps spinning, and a spool. Search for 360 continuous rotation servo. Sent from my SM-N986U using Tapatalk Last edited by Voodoobrew; 08-24-2021 at 08:53 PM. |
08-24-2021, 08:59 PM | #11 |
If the problem is that's a micro servo not a mini servo I would just get something like this Selizo 5 Pcs Retractable Keychain Retractable Badge Holder Reel Clip ID Badge Holder with Steel Wire Rope, Black https://www.amazon.com/dp/B07QKR1KCH...3RTJPFYFR9Y8BM A smaller servo won't have any power. Sent from my SM-N986U using Tapatalk |
08-25-2021, 03:59 AM | #12 | |
08-25-2021, 04:05 AM | #13 | |
Also the competition and courses are getting harder. The bungee just doesn't work as well as an electric winch. I'm running a scale electric winch on my C1 through an ESC and the winch is a lot more usable than the bungee. I think I'm going to wait for a bit. I am betting that with the new rules with SORRCA and other places about assisted versus unassisted recovery and bungees that there will be more servo winch options soon. | |
08-25-2021, 08:21 AM | #14 |
I just copied your link txt that was the reefs servo in the first post. Sent from my SM-N986U using Tapatalk |
08-25-2021, 10:05 AM | #15 |
08-25-2021, 07:49 PM | #16 |
08-25-2021, 09:12 PM | #17 |
No, that wouldn't work. It won't hold in neutral without gearing. Sent from my SM-N986U using Tapatalk |
08-26-2021, 06:14 AM | #18 |
I ended up going with the REEF 800IS. I am going to mount it laying down using the bracket for a Servo on Axle setup. |
Direct power mini servo winch - Similar Threads | ||||
Traxxas 8028 LED Power Supply can i wire direct to a 3s battery? | willygee | Traxxas TRX-4 | 8 | 04-17-2018 06:31 PM |
Power the Traxxas Rock Lights direct from rx | magic_yeti | Traxxas TRX-4 | 3 | 01-20-2018 01:38 PM |
rc4wd wireless winch run off direct 3s lipo ??? | greggreg2011 | Electronics | 0 | 08-09-2013 06:22 PM |
Can I power a winch and servo from the same BEC? | Sydwaiz | Electronics | 12 | 08-25-2010 05:27 PM |
