02-22-2022, 06:42 AM | #41 | |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Re: Copperhead cutting out Quote:
I have had constant issues with the Revolver and less frequent with a puller pro but still had problems and couldn't trust the two I got. One was a warranty replacement that had no box, no manual, just in a plastic bag dropped in a padded envelope and it looked like it hand been mounted before because of some scuffs. I bet they just dropped somebody else problem Copperhead in an envelope and sent it to me. | |
02-23-2022, 11:18 AM | #42 | |
Newbie Join Date: Apr 2010 Location: Crawlorado Springs
02-23-2022, 11:33 AM | #43 |
| Re: Copperhead cutting out Good luck, you probably talked to Joe. I sent mine in and they tried to charge me $75 to fix mine. It was only a couple months old. I bit6ched and they said warranty would cover it. Once I got it back I called Joe back and Castle and he said all they did was reset it, there was nothing wrong with it. Apparently somebody at Castle lied. Joe told me it was because my batteries were too small. I need to run at least 5K mah.
02-26-2022, 11:33 AM | #44 |
Quarry Creeper Join Date: Mar 2020 Location: Las Vegas
Out on the trail yesterday and my Copperhead 10 also shut down. Had steering but no throttle. Unplugged / plugged in the battery and it was all fine. !5 min later it did it again. Then the rest of the crawl no issues. My friend's also did the same thing a few times last month. s |
02-26-2022, 02:27 PM | #45 | |
02-26-2022, 05:40 PM | #46 | |
Pebble Pounder Join Date: Feb 2017 Location: Louisburg, NC
02-26-2022, 09:01 PM | #47 |
| Re: Copperhead cutting out I don't really care what he was saying. Every other ESC I have works using it the same way. I just heard somebody trying to feed me a line of crap.
05-19-2022, 11:45 AM | #48 |
Newbie Join Date: Apr 2006 Location: Genova, Italy
Has anyone tried the new 2.16 firmware to observe if the problem is solved? Castle said "Corrected low speed cutout when throttle engaged", so it could be possible... |
05-19-2022, 12:06 PM | #49 |
| Re: Copperhead cutting out My problem had nothing to do with throttle cut out on my Copperhead. I just would not go after sitting. There was a beta fix a while back but it caused chugging at low speed. Castle ended up giving me a MambaX and MicroX for free because of my problems. My MicroX2 does have throttle cut out (even with the punch at 40%) issues it if hit it hard right after turning it on or it you go back and force like you would if turtled and were trying to flip yourself back over.
05-19-2022, 05:24 PM | #50 | |
05-19-2022, 05:34 PM | #51 |
| Re: Copperhead cutting out They were helpful at first for me.
05-19-2022, 05:37 PM | #52 | |
05-20-2022, 08:20 PM | #53 |
| Re: Copperhead cutting out I have updated Castle link to version 3.85 and the software is ok: anyway, the Copperhead has the same problem also with new 2.16 firmware... I will contact the Castle support on Monday! |
05-21-2022, 01:38 PM | #54 |
| Re: Copperhead cutting out Nobody ever said they need a higher C rating. They were saying that you have to run a 5,000 mah battery with them. But even when I ran a large battery like that it still cut out
05-21-2022, 01:41 PM | #55 | |
If I were running trail or less than ideal conditions I think the Mamba X would be my go-to at this point. Maybe the sw4 but it does not have 4s capabilities. I doubt I'll ever buy another Castle ESC but I'll keep imamba x's and sw4s I have. They have been very good ESCs for me. Last edited by MOguy; 05-21-2022 at 01:44 PM. | |
05-29-2022, 07:15 AM | #56 | |
Quarry Creeper Join Date: Jun 2013 Location: Twin Lake
I installed one of the new Holmes hobbies Crawlmaster V2 with a 1400kv revolver. I only do trail and no comps, and it's been doing good for trails. 3 mile runs are common and it just barely warm. I did conformal coat it before I put the shrink tubing on, I don't go for water but I figured I should at it safe. One thing I didn't like was the low voltage is set to 3.0 volts and you need a serial programmer to change it and it's not as easy as the others (castle/tekin/hobbywing) to change it. Customer service guy at Holmes hobbies said 3.0 volts is fine and he runs his lipos down that far. No thanks, I like to not discharge my batteries that far. | |
05-29-2022, 03:36 PM | #57 |
Rock Stacker Join Date: Mar 2018 Location: Born in FL, stationed in Cali
This is a bummer as there are not many sensored ESCs in that price range of the Copperhead 10. Do I buy one and take my chances?
05-29-2022, 05:11 PM | #58 | |
That's a big heaping pile of BS. It's correct if we were talking about a bouncer or basher but in a crawler 450-850 mah packs are typical in competition where rigs are driven harder than on trail runs and whatnot. 🤦 I pay attention to what happens around me and what I read and I've read and seen maybe 10% of users happy with their copperhead escs. And that's a big maybe 10%, probably closer to 5% even the team drivers I know don't run them. | |
05-30-2022, 07:55 AM | #59 |
| Re: Copperhead cutting out Lots of people have the copperhead and have problems lots of people don't. I'm not willing to risk or give any more money to Castle so I'm done with them. It seems people are now having problems with the micro X2. I am having issues with the micro X2 Castle gave me as a replacement for the copperhead. It stalls after using full throttle on 4s. It just randomly stalls on 3s like the copperhead. I have a friend who's going to try the MicroX2 in his RC and see how it works for him.
05-30-2022, 07:58 AM | #60 | |
With the micro X2 on 4S it would cut out after you use full throttle a couple times, and on 3s it would cut out just like the copperhead. | |
Copperhead cutting out - Similar Threads | ||||
Just a Copperhead JK | 58_Willys | 1.9 Scale Rigs | 6 | 10-27-2018 02:13 PM |
Cutting a Cutting Board | BJoe | Tools, and Procedures | 37 | 12-22-2009 12:34 AM |
Copperhead | rckcrawler | Newbie General | 24 | 04-07-2008 07:20 PM |
cutting tranny when cutting bottom of chassis off... | dieselfuel | Newbie General | 1 | 02-23-2006 08:10 PM |
