Thread: battery life
Old 02-28-2007, 08:20 PM   #1
Default battery life
a 12v AA ( 10 AA nihm 1.2 batteries ) how much running time should they have and what is the best way to charge them ( time ) with a Input: 230V-50 Hz, output:15V-150mA charger
thanks
chivas72 is offline   Reply With Quote
Old 02-28-2007, 08:25 PM   #2
I'm a stupid C U N T!
slobin3d's Avatar
thanks
whats the Mah rating of the battery?
AA's dont have the discarge rate of 2/3 and 4/5 A's so they might give out on you if youre using them on a high power brushless, but 12v maybe not
slobin3d is offline   Reply With Quote
Old 02-28-2007, 08:29 PM   #3
2000mah
Old 02-28-2007, 08:34 PM   #4
slobin3d's Avatar
guessing by the specs of youre charger its not a peak charger, which you need for NiMh baterys, but if it is it would be a 12 hour charger, and a 2000 mah and single 55t lathe you should get about 45 minutes- hour, depending on how heavy you are on the throttle
Old 02-28-2007, 08:50 PM   #5
i guessed right it's not a peak charger
now that i see the battery it's wierd it has three cables
it's for a friend in france who has a f1 rc car and wants to replace his battery cuz he needs to charge 6 hour for 15 minute run time
the charger is just a regualr wall charger so no i'm out of ideas to help him out, cu he doesn;t have a peak charger
his kid i really giving him hard time about this
here are the specs of the original battery
12v AA 800 mHa 727
Old 02-28-2007, 08:57 PM   #6
slobin3d's Avatar
3 wires !?!
only time i see that is with balancers on lipo's
maybe the battery has a seperate charge and discarge lead??
Old 02-28-2007, 09:01 PM   #7
i'm asking for more info on the car and stuff i will post as soon as i have it
thanks for the help
Old 03-01-2007, 05:46 AM   #8
I was at future shop the other day and there was a roboreptile in the return bin for 20 bucks. When I took it apart the battery compartment had a common, a 3v, and a 6v lead. Im hoping yours isnt like that.
HndsWthtShdws is offline   Reply With Quote
