02-17-2022, 06:53 AM | #21 | |
| Re: Best esc for outrunners using 4s? Quote:
it seems the smaller outrunners are smoother than the larger ones i would think the hh snub nosed v2 would have better start up than a standerd sized hh outrunner i dont know what kinda space you have to work with but i think the sw4 1/8 version is good to 6s also the mm2 will take 6s too but both of those are huge and i do t know if the sw4 8th has the new programing that the 10th scale version has but it might be worth looking in to if you have the space for it | |
02-17-2022, 09:03 AM | #22 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
im running some pretty small 1800kv outrunners. smaller than what holmes offers. i will try the esc you mentioned, if they dont work well for startup ill try out some castle stuff.
02-17-2022, 09:09 AM | #23 | |
also the 120a is the only one ive seen rated for 4s | |
02-17-2022, 09:24 AM | #24 |
theres these i have 2 i use on outrunners but its only 2s capable but the rigs that run them are buttery smooth im runing them on the gold colored chinese outrunners a 2212 2200kv on a mrc platform and a 3530 1700kv in my d12 with no pinnion or spur just a direct drive to the transmission/tcase and there so quite they hardly make a sound Look at this on eBay https://www.ebay.com/itm/35A-ESC-Bru...-127632-2357-0 |
02-17-2022, 12:44 PM | #25 |
| Re: Best esc for outrunners using 4s? |
08-27-2022, 03:42 PM | #26 |
Rock Crawler Join Date: Mar 2021 Location: Santa Barbara
I'm using the AG Innovations Ninja esc on 4s with a 2500kv 3bros Acis motor. I don't use outrunners, but apparently it silences them, hence the ninja name. It's 6s capable, has a heat sink, and motor plugs come attached right to the circuit board. Cleanest setup I've seen so far. I have an earlier version with built in bec to power the receiver, while using a direct power steering servo. The new ones don't have a bec, due to users using them incorrectly, but NSDRC has a $10 micro bec that'd work great with it.
Best esc for outrunners using 4s? - Similar Threads | ||||
Check these outrunners out? | Frank211 | Electronics | 16 | 04-27-2020 12:40 PM |
Outrunners | monkeyracing | Tamiya XC/CC01 | 8 | 03-31-2013 06:11 PM |
Outrunners? | Jeepkid | Axial XR10 | 28 | 10-12-2010 03:09 PM |
High KV outrunners? | theslowguy | Electronics | 6 | 12-04-2009 03:26 PM |
