Affordable Outrunner Anyone has experience with more affordable outrunner options like the 9imod, Surpass or Rhinoesc? They are 35mm diameter and the specs seem good If I get anyone of those, there's any chance of running it with a Hobbywing 1080? |
Re: Affordable Outrunner Those are brushless motors. Hobbywing 1080 is for brushed motors. |
Re: Affordable Outrunner Quote:
Re: Affordable Outrunner i have a few of the 9imod crawler outrunneres the 3542 in2250kv there really nice if your gearing is low enuff and tge noise isent to bad with a cheap chinese eac i also have several gold can outrunners is different sizes and other than all the work that goes in to them to make them work in a crawler there nice too i have a 1450kv gold can outrunner in my trx4 2 speed on a 10 tooth pinion and i really like it but at some point it got hot and the glue holding the magnets in let go so i reglued them in and used opsickle sticks soaked in superglue to hold the magnets in place then sanded the rotor smooth and now it works great lol the start up is good and the sound isent bad ether the sound issue is mostly with castle escs there anoying on any brushless motor in my opinion anyway i have outrunner + cheap esc combos that are silent and have good start up |
Can you provide links for those gold can outrunners and ESCs? |
Re: Affordable Outrunner the gold can motors are alot of work to go from drone motor to crawler motor there sold under about 20 different names or no brand at all for the price differance your better off going with the unit already set up for crawling but ill post a link here are 1 of the escs i have been using i have alot of these escs they seem to work really good on outrunners the start up isent as good as with castle but vary close and dosent sound like a alian space ship taking off US $6.90 | Waterproof 45A 60A 80A 120A Brushless ESC Electric Speed Controller Dust-proof for 1/8 1/10 1/12 RC Car Crawler RC Boat Part rc https://a.aliexpress.com/_mKBufTG rinorc i have one on order but it hasent got here yet i figured i would give it a try US $29.39 36%OFF | RHINOESC EXPLORER 3542 1400KV/1850KV/2250KV Crawler Outrunner Brushless Motor 1/10 1/12 for RC Crawler Car Axial SCX10 Traxxas https://a.aliexpress.com/_mKltdzY ive got a bunch of these i really like them US $29.99 20%OFF | 9imod Outrunner Brushless Motor 3542 3532 Crawler Motor for 1/10 1/12 RC Crawler Car Axial SCX10 Traxxas TRX-4 TRX-6 Tamiya https://a.aliexpress.com/_mr6WaN8 heres a link to a hole bunch of the gold can motors US $12.24 21%OFF | 9imod Brushless Motor 2-3/4/5S D2830 D2826 D3548 D3542 D3536 D3530 For RC Mini Multicopters Plane Fixed-wing Aircraft VS DYS https://a.aliexpress.com/_mLBytEK |
Re: Affordable Outrunner Those last motors confuse me a bit. The shaft seem held on the part with the mounting holes |
i prefer the crawler versions that are already to go and have a 3mm shaft not 5mm and the crawler versions have more kv options available |
I'm afraid of making an expensive paperweight... I'm a machinist by trade. Does would help? |
US $18.60 40%OFF | 9imod 3542 3532 Crawler Outrunner Brushless Motor 1/10 1/12 for RC Crawler Car Axial SCX10 Traxxas TRX-4 TRX-6 Tamiya https://a.aliexpress.com/_m0JjmDU |
Re: Affordable Outrunner Ferp420, About the 45A ESC you got: Did you also get the programming card? |
Another thing: what ESC you've got? 45,60 and 120 are all the same price... I always prefer more power.... |
Re: Affordable Outrunner on my small outrunners i have been using a surpass hobby 35a esc the big ones i use the 120 amp version the 9imod crawler motors say they pull around 100 amps but when i was data loging the amp draw i was seeing 30 amps i guess it could draw more but thats what the esc sead it was putting out the data loging is another nice thing about the castle escs that the cheap ones dont have |
Re: Affordable Outrunner Finally got the outrunner. Got a 3536 1000kv and the 120a esc. Can you list your ESC settings? I'm yet to mount the motor but in the hand seems to not have drag brake. It offers little to no resistance to movement. I think I have the brake settings right but I could be wrong Edit: tried an old ezrun 25a esc and works slightly better than this 120a esc |
Re: Affordable Outrunner Ferp420, can you help with the question above? please |
Re: Affordable Outrunner What's question lol What did you end up getting and what did it go into pics are always helpful |
