03-30-2007, 07:48 AM | #1 |
Pebble Pounder Join Date: Aug 2004 Location: Vienna
| switch to brushless...worth it?
I am running a 2.2 TLT, 12.5" WB, with a Tekin Rebel 2, Integy 55T, and 7 Energizer 2500 mah AA batteries. Is the switch to brushless with a Mamba 25 and a recommended motor worth the switch? I have not driven a rig with this setup, so I am not familiar. But, there is a truck that trail rides with our group of friends, and his truck has crazy torque with that setup. Is a brushless setup more prone to rolling on a hill/ slant, or can the speedo be programmed or adjusted? Also, will NiMH get the job done, or is Li-Po essential? I want to build a rig for my son, and I may pull the speedo and motor from my crawler and replace with a brushless. |
03-30-2007, 09:14 AM | #2 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
The biggest reason I went with brushless is the drag braking. On a hill the vehicle will not run away, like it does with a brushed setup. Here's a clip of my 2.2 with a Mamba Max and GWS motor: A good setup, if you don't want to completely jump into brushless, is to just get a Mamba Max and run a brushed motor. The Mamba Max can run either a brushless or a brushed motor and be completely programmable with both. Meaning you can use drag braking on a brushed motor. The Mamba Max can be programmed using a computer and the included usb cable. The Mamba 25 requires a separately purchased Castle Link to be programmed with a computer. And is brushless only. NiMH will work just fine as long as you use high quality batteries. Last edited by SVEN; 03-30-2007 at 09:17 AM. |
03-30-2007, 09:26 AM | #3 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
do it... i have yet to see a "I hate my brushless" thread. All the reasons SEVN said plus, no maintenance, lighter body, and that ohh soo cool sound they make. |
03-30-2007, 09:34 AM | #4 |
I would say it is worth it, but a nice brushed motor is always good too (especially ran with the mamba max). You will need different batteries, as AA cells wont cut it. Lipo is not needed though. As far as sidehilling, if you get a lot of torque twist with your rig now, you will get more when you add power. |
03-30-2007, 10:03 AM | #5 |
I missed the AA part. They work ok for brushed, but when I tried them with brushless the performance was terrible. 8 Intellect 1400mah 2/3 A cells from Holmes is about the same price as 8 Energizers from Walmart. I've been using the Intellects for about 1 1/2 months with great results. |
03-30-2007, 11:34 AM | #6 |
So, is the Mamba 25 and Holmes Revolver the preferred setup?
03-30-2007, 12:16 PM | #7 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
You shave weight and add torque, gain drag brake, some make a high pitch sound that can be anoying but I like it. |
03-30-2007, 11:39 PM | #8 |
03-31-2007, 01:47 PM | #9 | ||
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
I was ready to bite the bullet and go brushless - before I educated myself a little on how brushed motors actually work and how to tune them. I'm getting really good stall-free performance w/ plenty of power out of my brushed setup now, due to a combination of a more suitable esc and a properly tuned motor. I'm currently running an Integy 65t lathe w/ a Viper RV15. Quote:
I'd still go brushless if money was not an issue for me now. A brushless set up sounds so much more versatile, you still get the grunt torque needed for crawling, but the very same set up will be capable of generating much more wheelspeed. I was able to get the performance I wanted with not too many changes to my current set up and not a lot of cash, so I went that route. I'll go brushless one of these days, though... Last edited by Big Mike; 03-31-2007 at 01:50 PM. | ||
03-31-2007, 09:21 PM | #10 |
Abso-friggin-lutely But you knew I was gonna say that. |
03-31-2007, 10:33 PM | #11 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
Ive done it twice and love every minute of it, went from a 55t/moped to a MM and hyperion and I have the same wheel speed but WAY more torque, it totally changed the way I drive. I'm putting a RR2/mamba25 combo in my landrover scaler now |
04-01-2007, 12:02 AM | #12 | |
I've tried some high end brushed motors that run cobalt magnets with HUGE brushes and coms in them. Powerful,yes they were....braking wise,not really impressed. They might have stayed put on a 45 degree slope. With the Mamba Max/Hyperion.....I've literally hung my truck on a near vertical ledge while deciding whether to NAIL the throttle or ease down to the bottom. With me though.....I usually just NAIL IT Brushless all the way,build bombproof first though Gobucks, Even if I was on a budget,theres no question,it'd still have a Mamba Max ESC. I'd probably start with a MM ESC and run a brushed 21-27t motor,then upgrade to a Hyperion later. Holmes Hobbies can hook you up with everything you need. | |
04-01-2007, 09:59 AM | #13 |
Pebble Pounder Join Date: Mar 2007 Location: kalispell
To run a mamba max esc on 2 motor set up do we need 2 esc's, does anyone have pics of a 2 motor setup with a mamba max, and does the mamba need any type of resistors, i might be saying that wrong but those things sodered onto the motor along with the wires thanks |
04-01-2007, 12:18 PM | #14 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Can't run 2 motors with one brushless esc. You need 2.
04-01-2007, 12:39 PM | #15 |
Quarry Creeper Join Date: Aug 2005 Location: Tucson
I was told you can run two motors with a Mamba Max..
04-01-2007, 03:53 PM | #16 |
04-01-2007, 04:37 PM | #17 |
04-02-2007, 12:40 AM | #18 |
| Quote: |
04-02-2007, 12:57 AM | #19 |
Pebble Pounder Join Date: Feb 2007 Location: Evergreen
I had problems with my brushless, but thats cause I can be special. After FEW Days of tinkerin and asking questions, no more problems.
04-02-2007, 01:21 AM | #20 | |
Gearing was 12/88 through a Losi triple-X tranny and using a GWS brushless motor in the video. I would say it is more the Mamba Max than the gearing, because I have very similar braking with a Lathe/MM and 15/88 gearing. However, if I had been using my Hyperion z3013 instead of the GWS, the bug probably would not have been rolling at all. It's a whole different animal than the smaller brushless motors. I have to be careful when driving down a hill, because if I let off the throttle too quick the vehicle will roll forwards. I have the drag brakes set to 100% whether I use a brushed or brushless. I also have my EPA's on my radio set to maximum. Everyone who drives my rigs say it is too touchy, because I set everything to maximum and let my finger do the controlling. That way I have maximum whatever when I need it. I don't know, maybe I do gear lower than other people, but I like to gear as low as I can and add cells to get more speed. Oh, and I still think brushless is worth it. Last edited by SVEN; 04-02-2007 at 01:31 AM. | |
