Thread: rear steer help
Old 04-05-2007, 01:59 PM   #1
Default rear steer help
This info may be on here I could not find it. I want to make my rear steer not return to center is it as simple as replacing the toggle any info on this would help thanks..
broncoholic is offline   Reply With Quote
Old 04-05-2007, 02:11 PM   #2
dystance's Avatar
yes, replace the toggle with one that stays in place. The first independent rear steer setup I did used a toggle that did not return. I like the self centering better by far.
dystance is offline   Reply With Quote
Old 04-05-2007, 02:25 PM   #3
There just seems to be no steer control it eather all the way or centered
Old 04-05-2007, 02:28 PM   #4
its gonna be the same wether the switch is self centering or not as the channel is non proportional. either way you'll have center and full throw to either side.
Thorsteenster is offline   Reply With Quote
Old 04-05-2007, 09:55 PM   #5
Thanks
Old 04-06-2007, 09:05 AM   #6
High Plains Drifter...
Big Mike's Avatar
You'd have to really get used to rear steering that did not self-center.
I used 2 momentary pushbuttons, and that's how my set up is - either centered or all the way one way or another. It does annoy me sometimes.
I've seen a TQ3 in a thread here somewhere, modified with a 2nd self-centering wheel for the rear. That's the set up I want to try. You'd have full control of the rear steer with your left thumb...
Big Mike is offline   Reply With Quote
