Thread: integy motor springs
Old 04-06-2007, 06:56 PM   #1
lohocla's Avatar
Default integy motor springs
anyone know where I can get springs for a integy 55t lathe motor, Ive searched here and a couple hobby shops. cant find anywhere that has em. I was about to tear the axle apart cause I had the motor in my had and it was spinning then nothing would happen when it was in, I thought a shaft or something was broke somewhere and bound up. then I noticed it missing when I was about to check the brushes first, It must have jumped off somewhere when I was trailridin out back. any help is much appreciated. even a ghetto rig is cool until I get a spring.
Thanks
lohocla is offline   Reply With Quote
Old 04-06-2007, 07:26 PM   #2
K_B
Wouldn't just about any standard brush spring work?
K_B is offline   Reply With Quote
Old 04-06-2007, 07:34 PM   #3
Gold Star Baby!
DARKHORSE's Avatar
I wouldnt see why not..
DARKHORSE is offline   Reply With Quote
Old 04-06-2007, 08:19 PM   #4
i have used different brush springs on different motors before.
mrmaxxman is offline   Reply With Quote
Old 04-06-2007, 11:40 PM   #5
lohocla's Avatar
Im not sure, you tell me.
Old 04-07-2007, 06:45 AM   #6
RC4WD Team Mgr/W.Pa.C.
Rckcrwlr's Avatar
I just bought a set of HD springs for mine. They are just standard springs...make sure that you have the correct ones. When looking from the top the part that presses against the brush should be on the bottom right and the straight part is on the top left.
Any LHS should carry them.
Rckcrwlr is online now   Reply With Quote
Old 04-07-2007, 01:55 PM   #7
I crawled that crack
hotwheels000's Avatar
The purple springs will apply more pressure to the brushes and your motor will perform better also. I have also seen some silver springs that are stronger than the purples but have not used them.
hotwheels000 is offline   Reply With Quote
Old 04-07-2007, 07:05 PM   #8
The purple springs from Trinity are what most people here use:
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXJV94
I bought 6 sets myself. I noticed a difference on my TLT's with them. With my TXT, no difference, just too heavy.
bluonyx is offline   Reply With Quote
Old 04-07-2007, 07:54 PM   #9
lohocla's Avatar
thanks for all the help. I called the lhs shop and he said he has brush springs in stock so I will check it out monday.now all I have to do is get my shock mounts to stop sliding all over the place on the links and ill be ready to hit the trails.
