| | #1 |
| Pebble Pounder Join Date: Dec 2006 Location: longmont
| Does a holmes hobbies adapter plate work w/a eflite power 10 ? |
| Sponsored Links | |
| | #2 |
| I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| the 10 is a larger motor than the 300-400 sized motors there designed for. I believe that it is more like the hyperion that JRH sells and they need no adapter but the shaft has to be machined to 1/8 or use 5mm pinions but i;m not 100% sure |
| | #3 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| The power 10 bolts up to a standard 540 mount. It has a 5mm shaft so you will either need to talk to a machinist to turn down the shaft, or use a 5mm pinion. |
| Thread Tools | |
| Display Modes | |
