Thread: battery help
Old 04-10-2007, 07:05 PM   #1
Default battery help
Ok guys would a battery for an rc18t (6 cell 7.2v 1100mah nimh) work on my bmvii crawler ? esc i'm using is a novak xrs. I like this battery becouse its smaller than my 6cell 7.2v 3300 mah nimh
tapped-out is offline   Reply With Quote
Old 04-10-2007, 07:51 PM   #2
K_B
It would most definitely work. I use those 2/3A packs on all of my trucks. I would suggest a seven cell pack. It'll give you a little extra "oomph".
K_B is offline   Reply With Quote
Old 04-11-2007, 08:17 AM   #3
High Plains Drifter...
Big Mike's Avatar
That pack will work fine, you'll just get like half the run time from it. (1100mah vs. 3300mah)
7 cells would give you a bit more power if that's what you want. If a size decrease is all you're really after, you'll just sacrifice some run time with the RC18 battery.
Big Mike is offline   Reply With Quote
