Thread: Settings for Mamba Maxx
Old 04-10-2007, 11:22 PM   #1
Default Settings for Mamba Maxx
post your settings of your Mamba Maxx.. This ESC is AWESOME....
Azcats1 is offline   Reply With Quote
Old 04-10-2007, 11:23 PM   #2
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
forward to brake to reverse
100% reverse
100% brake
50% drag brake
0 punch control
High start up power
normal timing
JohnRobHolmes is offline   Reply With Quote
Old 04-10-2007, 11:27 PM   #3
100% reverse
100% brake
50% drag brake
0 punch control
High start up power
normal timing
I have my Drag brake around 75% other then that mines the same.
Old 04-10-2007, 11:34 PM   #4
Keep it real
Tanis's Avatar
Mine's the same, except I have it at 100% dragbrake, but I am going to change it back down to 50%, as that is enough to hold it on as steep a hill as it will stay on without rolling over, with the 100% it just drains the battery quicker.
Tanis is offline   Reply With Quote
Old 04-10-2007, 11:35 PM   #5
What about the throttle curve and the brake curve..
Old 04-10-2007, 11:38 PM   #6
Keep it real
Tanis's Avatar
I left mine stock, but on my daughter's, I made it so you have to use more trigger to get it to move, so she can control the low end better.
Old 04-10-2007, 11:38 PM   #7
Colt Python/SR9c
TwistedCreations's Avatar
ok dumb question... When setting up 2 of them, can you set the rear up with a higher drag brake, than the front?
TwistedCreations is offline   Reply With Quote
Old 04-10-2007, 11:49 PM   #8
RedRockafarian
STEW<CO>'s Avatar
Yea, that was a dumb question
STEW<CO> is offline   Reply With Quote
Old 04-10-2007, 11:52 PM   #9
Keep it real
Tanis's Avatar
I don't see why not, if you mean 2 esc's.
Old 04-11-2007, 12:03 AM   #10
Tanis and runnin2jpn, are you running brushless or lathe motors? And is anyone running 2 lathe motors and one mamba max? If running this combo, will it hold it on a steep incline?
flexmonger is offline   Reply With Quote
Old 04-11-2007, 12:38 AM   #11
Keep it real
Tanis's Avatar
I am running an Integy 55t handwound brushed motor, in a 2.2 TXT.
Old 04-12-2007, 01:15 AM   #12
I run 2 55t integy's and mamba max. holds like super glue.
TiminAZ is offline   Reply With Quote
Old 04-12-2007, 01:39 AM   #13
I'm running 2 lathes and the Mamba Max. No issues here. Working just fine on my 2.2 Clod.
Old 04-12-2007, 07:30 AM   #14
Im having a hard time convincing myself I need to drop the CHEDDA on one of these. Really worth it? Is there a good cheaper alternative? Im just trying to figure this out.
thanks for the imput
Rok_Dok is offline   Reply With Quote
Old 04-12-2007, 08:19 AM   #15
Nothing else out there can do eveything the MM can. The drag brake alone is great for us crawlers. Got one in the super clod and want to put another in the 2.2 when it gets finished up. This thing rocks!!!
DeaDShorT is offline   Reply With Quote
Old 04-12-2007, 08:47 AM   #16
I just installed a mamba max and a himax out runner in my 2.2 Falcon. Should be sweet! I cant wait to get it on the rocks!!
hkusp45 is offline   Reply With Quote
