| | #1 |
| Rock Crawler Join Date: Dec 2006 Location: here
| whats the highest mah i can get w/a 2/3a? can also can I use a lipo battery w/novak xrs esc |
| Sponsored Links | |
| | #2 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| The XRS will work with a 2 cell lipo, but you will need a voltage cutoff to prevent damage to the lipo. I believe novak makes one. Lipo of choice-- what motor you running? The higherst mah 2/3a is the ELite 1500. |
| | #3 |
| 55t lathe is the motor i'm running how much will the 1500 mah run more than 1100 mah I get about 12-15 min run time w/11mah Last edited by tapped-out; 04-15-2007 at 01:30 PM. |
| | #4 |
| I would give it 20 minutes based on your current runtimes. Sounds like something is either binding in your drivetrain, your batteries are crapped out, or you are not just crawling around. You should get longer runtimes than that. |
| | #5 | |
| RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
Like JRH said, either something is seriously binding in your drivetrain, your batteries are old or are cr@ping out... OR, your charger isn't giving a full charge. Do you have a decent charger? Peak charger? | |
| | #6 |
| Quarry Creeper Join Date: Sep 2005 Location: Sydney, Australia
| i run a 55t and 1400mah i get around an hour |
| | #7 |
| would bushing in trans make the differnts in run time?Black widow peak chrager. Heres a pic of rig drive train see any thing I should change?Not using the green battery any more but w/green batt longer run time. axle was twisted before it went on this rig. So how can I test battery on meter for full charge? thanks guys ![]() |
| | #8 |
| Ok guys looked at every thing drive train not binding charger??? etc. battery must not of been charging right recharged took almost 1 hr. to charge but my run time was 25-30 min thank for the help |
| Thread Tools | |
| Display Modes | |
