Thread: reversing rotation on a Brushless motor
Old 04-14-2007, 04:50 PM   #1
Default reversing rotation on a Brushless motor
Can you reverse the rotation of a brushless motor?
I just got a mamba maxx ESC and a brushless motor, how would I go about reversing it?
xjman is offline   Reply With Quote
Old 04-14-2007, 04:54 PM   #2
Kamikaze's Avatar
Just switch any two of the three wires running to the motor.
Kamikaze is offline   Reply With Quote
Old 04-14-2007, 04:55 PM   #3
It doesn't matter what ones? Will I still get the punch I would normally?
Old 04-14-2007, 05:05 PM   #4
TCS/Holmes Hobbies
SVEN's Avatar
Doesn't matter which ones you switch. It won't affect the performance by switching them.
SVEN is offline   Reply With Quote
Old 04-14-2007, 06:12 PM   #5
Scattman's Avatar
Yep, just switch any two.
Scattman is offline   Reply With Quote
Old 04-14-2007, 06:33 PM   #6
Well, these brushless motors lay down the law in a serious way, defentally puts the pep in the TLT
Old 04-14-2007, 06:36 PM   #7
YOU Dumb A## you said you were putting that thing in the TC4 when I sold it to you!!!!! Why didnt you call me for the solution anywho? We gonna hang tonight?
Rok_Dok is offline   Reply With Quote
Old 04-14-2007, 08:15 PM   #8
Scattman's Avatar
Liking that brushless power are we? What ya' running in there?
Old 04-14-2007, 08:19 PM   #9
Its a 5700 from castle creations, its actually going in my TC4, but with the weather outside there wasn't enough room to let 'er rip.
So, I have the Green Meanie sitting there, and threw it in. Ballooned up the electronics, and went and hydroplaned across the puddles.
If I found dry land it would instantly pop a wheely. Kinda wondered how the axles hung together.
Old 04-14-2007, 09:15 PM   #10
The water. Less grip on the tires = less strain on the drivetrain.
Mad Scientist is offline   Reply With Quote
Old 04-14-2007, 09:22 PM   #11
Yeah, but when you go from puddle, to hard rock, to airborne, back to the ground makes you cringe.
I just can't wait to actually get a crawling brushless.
Old 04-15-2007, 12:31 AM   #12
Wasn't there an article awhile back , that the author tried to run a BL set up in a motor and it turned out to be " Not Possible cause it was BL" ?
I believe the article was showing it in a bruiser .
SO my question, are you sure its all you have to do is reverse 2 of the wires ?
PROTOTYPE is offline   Reply With Quote
Old 04-15-2007, 01:20 AM   #13
TCS/Holmes Hobbies
SVEN's Avatar
This is from the Mamba Max esc instructions: http://www.castlecreations.com/suppo...er%20Guide.pdf
page 4 bottom right
"After the calibration process below, it may be necessary to swap two of the three motor wires to provide the correct rotation when forward throttle is given. There is no polarity on the three ESC-to-motor wires, so no worries about which one from the ESC goes to which one on the motor."
Old 04-15-2007, 01:42 AM   #14
HMMMM very interesting!!
Thanks for the info.
I wonder why the author was not able to run the brushless motor ?
Old 04-15-2007, 10:03 AM   #15
TEAM MODERATOR
Reflection's Avatar
He couldn't run brushless in a motor because it was brushless???????????
Reflection is offline   Reply With Quote
Old 04-15-2007, 09:59 PM   #16
Apparently cause the way the stock tranny is in the bruiser and the position of the motor a BL motor wouldn't work. I wish I could find the magazine
Old 04-15-2007, 10:11 PM   #17
I'm a stupid C U N T!
slobin3d's Avatar
you can run a brushless in place of any like sizes motor, but the bruisers used much larger motors than a 540, so maybe he couldn't figure out how to transplant it
slobin3d is offline   Reply With Quote
Old 04-15-2007, 11:15 PM   #18
TEAM MODERATOR
Reflection's Avatar
Really makes no sence now
You can get MORE power out of a SMALLER outrunner compaired to your typical 540 can. Therefore it should be EASIER to fit in the same spot Switching the motors direction is as simple as unpluging the wires and swaping them.
Old 04-15-2007, 11:17 PM   #19
This is obviously a lost cause , till i find that damn article. :-(
Old 04-16-2007, 11:06 AM   #20
K_Willis's Avatar
My guess is it might have been one of the novak brushless systems. They are sensored and the earlier systems were not reversible. Luckily the new novak crawler system is.
K_Willis is offline   Reply With Quote
