| | #1 |
| The Wheels Keep Turning ![]() Join Date: Jan 2004 Location: Phoenix, Arizona
| i'm running one magnetic mayhem in my emaxx. originally i had a super rooster in it but needed it for my clod. now i have a tekin rebel and it's not cutting it. I will spend the money for another super rooster if i have to, but does anyone know of another good less expensive ESC i could use? thanks. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jan 2004 Location: Ontario, Canada
| You could use a LRP controller and you could even get it waterproof. I would just buy a Super Rooster though. jugg_crawler |
| | #3 |
| Newbie Join Date: Jan 2004
| I would go for LRP f1 pro I use it in my TXT and its great!!! two motors(stock for now) and it give a lot of power and run very cool, and is best point is that he dont have motor limit!!!!!!!!!!! bar the israeli crawler |
| | #4 |
| Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
| kevinlongisland- What about the Tekin Rebel did you not like? I was thinking of using one with a single Maxx Titan in an Emaxx based crawler so I would only need one battery. Did it overheat or give you problems? I didn't really want to use the stock EVX and run two batteries. Unless anyone knows how to wire it to run 1 motor and 1 battery. |
| | #5 |
| I wanna be Dave Join Date: Jan 2004
| I too, would like to know why the Rebel is "not cutting it." If you are using only one motor, a regular Rooster would also be a good choice. I use one and it never heats up! |
| | #6 |
| after running for about 5 minutes, the rebel stops supplying power to the motor. if you let it sit for a minute or two, it works again. the heat sink is not getting hot, it does get warm. i believe it is going into thermal protection. |
| | #7 |
| what are the specs on it. That is rediculous if it's going into thermal protection mode with a 22 turn motor.....even if you are running very slowly. You should try a little fan if you plan on keeping it. |
| | #8 |
| i have to run a test one day to see what the current draw is of these motors when they motor is locked (not turning) and you give it full throttle. i believe these are the conditions that are causing it to shut down. the spot i was crawling in put the truck in allot of awkward positions were the wheels were locked often. |
| | #9 |
| Pebble Pounder Join Date: Nov 2004 Location: Lakewood,CA
| Wow... thats dumb. My Super Rooster heats up pretty hot when i crawl with 17T doubles.... Nothing to stop me though. Also, why is everyone moving to the Tekin Rebel 2? What happened to the Super Rooster? |
| | #10 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| is it a Tekin rebel or the Tekin rebel II ??? |
| | #11 | |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| Thread Tools | |
| Display Modes | |
