Thread: Radio?
Old 01-28-2004, 05:42 PM   #1
Default Radio?
What kind of a radio would you guys suggest buying for my Juggernaut 2 crawler?
jugg_crawler
jugg_crawler is offline   Reply With Quote
Old 01-28-2004, 09:52 PM   #2
Default Re: Radio?
It depends on how much money you want to spend. Any 2 channel radio will do fine. An AM radio will do just fine because your not running your car more then 20 feet from you. You can pick up an am radio super cheap too. But if you want you could get a lower end 3 channel FM radio like the Hitec aggressor. You wont need a digital radio with all kinds of special settings that were designed for racing. A simple radio will do just fine for a rock crawler.
RcRock-Guru is offline   Reply With Quote
Old 01-29-2004, 06:14 AM   #3
Default Re: Radio?
I proably want to go computerized but thanks for the help! I will look into them later on.
jugg_crawler
Old 01-29-2004, 09:18 AM   #4
Default Re: Radio?
I am a fan of the JR XR3. Digital yet simple. 3 channels and models. 3rd channel can be Linear, toggled or disabled.
Great radio for the price.
zBigBadWolf is online now   Reply With Quote
Old 01-29-2004, 03:10 PM   #5
Default Re: Radio?
Ya that is the same radio I am using with my TxT-1.
Old 01-29-2004, 06:41 PM   #6
Default Re: Radio?
Thanks. That's probably what I will get.
jugg_crawler
Old 02-23-2004, 07:48 PM   #7
Default Re: Radio?
you should look into the airtronis mx3 it also 3 channel it 5 moddle memmory and it a litle cheaper also rcca seemed to like it more than tha jr
jmirsberger is offline   Reply With Quote
Old 03-01-2004, 12:58 AM   #8
XFACTOR's Avatar
Default Re: Radio?
i like the Futaba 3pk.. thats the controlle rim gonna get soon.. as im told its easy to use and filter between chanels.. atm i have a jr xs3.. but the Futaba is better..(i think)
ryan
XFACTOR is offline   Reply With Quote
Old 03-09-2004, 04:24 PM   #9
Default Re: Radio?
I'm using the HiTec Agressor CRX for my TXT and it works great...I have it set up so that I can make the truck 4WS and 2WS quite fast (it is not just the flick of a switch, I have to acess the meny but that doesn't take that long, ~2-3 sec)...great value...
DCLXVI is offline   Reply With Quote
Old 04-06-2004, 12:15 AM   #10
Default Re: Radio?
I also use the Hitec Aggressor CRX and think its great. Simple to use and does everything I need.
DCLXVI, I assume you set up 2 different models and switch between the 2. You can just drive in the programing mode all the time that way you can switch it with one button. I also setup a model for crab steer and rear only steer as well to increase my options, change the model name to what it's set as (4ws, Crab etc) and it tells you on the screen which mode your in.
I had a 3pk but chose this control over it because it was more comfortable to use and has all the important functions of the 3pk anyway and was less than half the price if you include the digital servos you have to buy to use the 3pk properly.
TXTFUN is offline   Reply With Quote
Old 04-06-2004, 11:53 AM   #11
Default Re: Radio?
Hmmm...haven't though about that...well I fried my ESC (water in the case, shorted some FET's) the other day so I'll guess that I'll have to wait awhile to try it...
Old 04-06-2004, 02:43 PM   #12
Moderator
RXcrawler's Avatar
Default Re: Radio?
Could you use a 4 channel radio such as the Futaba 4VWD
http://www2.towerhobbies.com/cgi-bin...I=LXBCP2**&P=7
I know you wouldn't have the "steering wheel" but wouldn't it give you full control of the rear steer without having to switch profiles?
RXcrawler is offline   Reply With Quote
Old 04-06-2004, 03:38 PM   #13
Default Re: Radio?
Yes you could but I bet that it would be trick to keep track of two sticks for normal running...
Old 04-06-2004, 10:14 PM   #14
Moderator
RXcrawler's Avatar
Default Re: Radio?
I was thinking you could use one stick (probably the right one) to steer the front. Then use the other: up & down for foward and reverse and left & right for the rear steer. I figured it would take some (maybe a lot of getting use to.
Old 08-26-2010, 01:20 AM   #15
any links to where i could find good deals on radios
bndt71 is offline   Reply With Quote
Old 08-26-2010, 02:09 AM   #16
Tower has the 3pm-x for $160 right now,, or buy a star and check the classifieds section on here for a used radio.
Failedabortion is offline   Reply With Quote
Old 08-26-2010, 08:27 AM   #17
Holly! Old threads!??
oldhippie is offline   Reply With Quote
