Charger question i searched and didn't find a definitive answer. i just bought a new charger to use with my boat. when it asks you to set the threshold whats that mean(3mv-20mv)? I'm using a 6 cell NIMH 3600 pack what should it be set at? I've never really dealt with good chargers before any help? |
if you really want to get techincal waht kind of pack is it? is it a cheap stick pack or a high quality matched cells, do you equaliise? but for 3600's you should go with 3mv"thumbsup" |
another question are you discharging before you charge? otherwise leave at 3mv and dont worry about"thumbsup" |
3mv is probably a tad bit low. Most likely won't even get warm there. You can start there but you will find that 5-7mv will be best. You want the batt. warm at the end of the charge. Not hot, just warm. |
thanks for your help"thumbsup" |
So if you wanna correct somebody, make sure you know what the hell you're talking about. |
thanks scattman. the pack worked perfect set at 5mv. |
Nimh peaks at about 140f. If they are not getting that hot you are not getting a full charge. |
5-7mv is right, thats what I told him on AIM, and yes I sold him the charger, so im pretty sure im right on this one. I charge all my packs at 1.5-2.5amps on 5-7mv. The amps so low because more runtime then punch (punch goes down fast, so myswell go for runtime) Ill be sending you a letter with the manuals/setup guide, I forgot to send with you, I found them yesterday. You want em?, if so pm me with ur addy. |
132f is close enough if you dont care about a bit more runtime. If you want a higher voltage or fuller charge just bump up the mV a bit more. |
