05-28-2007, 08:14 PM | #1 |
Quarry Creeper Join Date: Mar 2007 Location: northern utah
| help with glitching!
hey guys im having some glitching problems, it seems like it started when i put a new servo in. im running a airtronics m8 with a novak xxl receiver and rooster esc,integy 55t, i just got a jr st126mg servo and it is glitching pretty bad now, any suggestions? im getting sick of glitching off cliffs! thanks guys |
05-28-2007, 08:21 PM | #2 | |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
if you still have the glitch its not the servo but something else how close is the rx to the batt and servo and esc are they all right next to eachother | |
05-28-2007, 08:25 PM | #3 |
I've been having some glitch troubles until now. Come to find out,my radio was causing it. I think the steering pot is going bad. Might be something to check.
05-28-2007, 08:39 PM | #4 |
well i had a futaba 3003 and it was ok, id have little ones here and there but i think its this servo, and its brand new. i have the battery in the very front and the esc and rx in the back of my k2-3l on a lexan plate
05-28-2007, 08:58 PM | #5 |
Maybe..... I thought mine was the servo as well. Put a new one in there and it worked....for a bit. My glitching was kindly hit and miss. It would act up and then go back to working fine. Might not hurt just to double check with another radio. |
05-28-2007, 09:25 PM | #6 |
Pebble Pounder Join Date: Jul 2006 Location: Superior wi
how used is your M8 ive got a couple M8's andone is really used and the steering pot is worn but that dosnt cause glitch issues more centering issues but ive had a tx module with bad/loose connection inside it cause glitch issues. just speaking about my experence with M8's otherwise i love mime(the good one) i race and crawl with it all the time without issue. |
05-30-2007, 06:57 AM | #7 |
Rock Stacker Join Date: Jun 2006 Location: Norway
Also check your reciever antenna. The soldering of the antennacable are often bad. Open up and resolder.
